Date: 06/24/2020 06:12 am
NOS Sedan decklid
Date: 10/23/2019 11:51 am
Esslinger 2.0 intake
Date: 03/06/2017 11:58 am
Date: 05/13/2021 05:33 pm
Date: 03/23/2018 09:23 pm
Date: 01/28/2021 03:49 pm
Clutch/brake pedal assemble
Date: 12/21/2017 11:26 am
1971 Pinto 5.0L
Date: 12/02/2017 12:23 am
Clutch Fork
Date: 03/31/2018 09:12 pm
  • Online today: 394
  • Guests: 282
  • Total: 282
Hedman 2 Piece Header
Started by Pangra74, March 20, 2010, 03:20:42 PM
Pangra74
Kyle,
I assume you're talking about the flange from the header to the exhaust, right?
1974 Orange Runabout
wingman72
I used heavy duty springs on the tabs, so when you bottom out the exhaust has some give.
Kyle
2nd place Mid Am Championship 2000,2001, 1st place 2008
Pangra74
Hey.....pop rivets. That's even easier if they don't leak! Maybe even a pair of short sheet metal screws on opposite sides!
I even bought a set that were pop riveted together. They are VERY GOOD headers. And they FIT!!!!
Pangra74
Yep, I sort of figured something like that. I'll probably just make up some small angle brackets and have them welded on and use thru bolts.
Joe
When new they had tabs that were welded to each half and then bolted together. I've also welded the two together with no problems.
Pangra74
Any of you guys running a 2 piece Hedman street header? Is there a special clamp to hold the upper amd lower tubes together? The tubes slip together nice and tight, but I assume they need to be clamped so as not to come apart under exhaust pressure. I can make up a clamping system, but wondered if any of you know if there was a Hedman part.
Joe
