74 Pinto wagon armrests
Date: 01/18/2017 07:04 pm
1978 Squire wagon 6 Cly
Date: 02/16/2020 05:42 pm
13" Style Steel Trim Rings
Date: 10/09/2020 10:35 pm
Rear brake shoes
Date: 01/23/2017 05:01 pm
Date: 04/12/2017 06:57 pm
Date: 07/08/2022 11:51 pm
79-80 full glass hatch
Date: 01/04/2017 04:04 am
Date: 06/22/2017 07:19 am
Built 2.0
Date: 10/07/2018 05:27 pm
  • Online today: 529
  • Guests: 457
  • Total: 457
Can you use a 2.0 flywheel and clutch on a 2.3 ?
Started by pintomadness, March 18, 2010, 05:02:51 PM
Be carefull using the double-drilled flywheels on an engine with good HP, I broke the center out of one with my hopped-up nitrous injected 2.0, the flywheel was rated for up to 200 HP. (??)  :lol:
pintomadness
Hey thanks for the help ,one more pinto on the road !
Yes and NO. Flywheel is the same BUT the bolt pattern is different. Aftermarket flywheels are double drilled for both bolt patterns. Clutch should be the same for both 2.0 & 2.3.
The easiest way to tell is looking at the oil filler cap. If it's towards the front of the engine it's a 2.0 and if it's towards the rear it's a 2.3 . ;D
pintomadness
I have the minivan 5 speed in my 1973 wagon too . How do you tell a 2.0 from the 2.3 ? The engine in the pinto has a lot of H.P. stuff so it makes it hard to find out what it is  .The car has lots of mods so it could have been changed to a 2.3 . I found a mint running 2.3 for a 100 bones so I just need to know if I can use my tansmission stuff . Thanks !
