Date: 01/28/2017 12:30 pm
2.8 Engine mount brackets
Date: 12/28/2016 11:42 am
Date: 08/09/2018 07:49 am
Date: 12/24/2016 04:13 pm
Date: 01/20/2018 07:51 pm
Date: 04/24/2018 11:45 am
1980 Ford Pinto For Sale
Date: 07/01/2018 03:21 pm
1980 Pinto Pony for sale
Date: 08/21/2021 03:54 pm
Date: 07/17/2019 05:23 pm
  • Online today: 553
  • Guests: 460
  • Total: 460
what is the fuel line psi. on a stock 1980 pinto 2.3l???
Started by flyboy1, March 16, 2010, 12:08:39 PM
the stang would have a 88lph pump factory.. i used the pinto lines on mine the large one to feed and the small vent line for the return.... where the vent line goes into the top of the tank , remove that fitting and look inside the spot where the hose connects to it... it is a very smalll hole.... drill this hole out to the inside diameter of the metal tube section and then i just drilled a hole in the gas cap to vent the system.. without a vent it will vapor lock..
flyboy1
im swaping the 2.3l in my pinto to a 2.3l out of a 93 mustang and the new mustang 2.3l needs an electric fuel pump...what i need help finding out is how much psi. the stock pump was pushing so i can find a good replacement pump.....and also what am i suposed to do with the return line to the tank????
i am using the stock pinto carb and intake system....the new 2.3l does not have the lobe for the stock fuel pump that is why i need the stock pinto fuel line psi. spec. so i can buy a maching electronic one..... :)
