Date: 06/28/2019 09:14 pm
Date: 06/25/2021 12:59 am
Date: 09/10/2018 10:41 pm
Date: 05/13/2021 05:33 pm
2.3 front sump oil pan
Date: 02/19/2017 03:24 pm
Front sump oil pan
Date: 01/02/2017 06:54 pm
74 Pinto Rear Side Lights
Date: 02/18/2017 05:47 pm
Date: 12/24/2016 04:13 pm
Many Parts Listed Below
Date: 04/20/2018 11:15 am
  • Online today: 2,567
  • Guests: 2227
  • Total: 2227
YOU SHOULD !!!!!!
Started by Starsky and Hutch, March 14, 2010, 10:46:46 AM
80/20   And I have no gel
Nope, 50/50 is actually the recommended ratio in most climates
Thank you! I was just curious.
Now, does that make my coolant less effective or last less time?
50/50 is half water, so you will be fine.
I've always run 50/50 from the pre-portioned prestone bottles, is that okay? I've never had any problems with it gelling or anything either.
I live on Vancouver island and i run 80/20 and i use prestone pure
78_starsky
"Also i run close to pure anti freeze"   <<  where do you live? and why would you want to run pure anti freeze?  I was always led to believe that anti freeze needs at least to be mixed 60/40. to get the right balance to not gel.  or are you running pre-mixed at 100% strength>?
Quote from: blupinto on March 14, 2010, 10:10:02 PM
just remember to keep antifreeze away from the pets and kids. :o :police: ;D
Excellent advice!!!
Seriously? I really did not know this! Looks like I have another excuse to get out and work on the Pinto! :D ;)
Thats the way to make them last longer..... Also i run close to pure anti freeze
I do that along with power steering fluid and anti freeze.  Fred   :)
You should change your brake fluid once a year.......Power vacuum bleeding is fast and you can make your own out of a large plastic or glass jar some hose and a vacuum cleaner...
