Date: 02/27/2017 10:10 pm
Date: 02/14/2018 01:34 am
72 pinto and 88 turbo coupe
Date: 06/09/2016 04:13 am
Date: 06/28/2019 09:14 pm
1973 Pinto Pangra
Date: 07/08/2019 10:09 pm
Date: 10/28/2018 08:45 am
72 Pinto
Date: 03/07/2019 12:07 pm
2.8 Engine mount brackets
Date: 12/28/2016 11:42 am
  • Online today: 600
factory tach
Started by 72pair, March 13, 2010, 09:07:54 PM
flash041
Mine quit working long ago.I just swaped it out with another one , it works fine now.Seems there mush be a way to repair it.I will talk to an electrial guy today to see if he can help.
I swapped mine out today with a different one and my problem went away.  I took one apart as well.  In my opinion, it will take someone with some knowledge on them to repair them.  You may be better off replacing it with a known good unit.
mine does the same thing but when i hook to the wire from the tach at the back of the cluster to a remote tach it works perfectly. so my tach section on the gauge cluster is bad. i need a new one or just to remove the cluster and mount a speedo and tach behind the Original cover section from the gauges.
Mine is acting up as well.  It bounces between the actual rpm and about 500 rpm higher.  I think I am going to swap it for another that I have to see if it is the tach or something else.  I had to repair my engine harness already so I hope there are not new issues there.  I am lucky though that my housing is nice and solid.  Have you checked your wiring just in case?
72pair
Anyone have any insight into factory tach problems? My 80 bobcat tach just bounces between 0-1500rpm. I haven't attempted removing the cluster due to the known fragile nature of these housings. Is there a common problem and does someone repair them? Any help? Thanks, JT
