Date: 07/08/2017 08:53 pm
KYB shocks
Date: 02/08/2017 07:09 pm
Date: 01/10/2022 03:41 pm
Date: 12/09/2016 08:34 am
Wanted - 71-73 Pinto grill
Date: 12/15/2016 03:32 pm
Mustang II V8 swap parts
Date: 03/26/2017 02:25 pm
SOME PARTS FOR SALE
Date: 01/11/2017 10:45 am
Wagon hatch letters
Date: 12/31/2023 04:24 pm
Date: 08/13/2018 02:46 pm
  • Online today: 548
  • Guests: 511
  • Total: 511
motor mounts for 2.3
Started by Pinto_dude, December 30, 2004, 08:11:05 PM
CHEAPRACER
If you originally had a 2.3 in your Pinto then the stock pinto mounts will work. If it had a 2.0 then someone else will have to step in. Also, when did they start using the 1 piece rear seal? This adds another issue of using the stock Pinto oil pan on a late model 2.3. I gave up on using the rubber pan end seals and use straight silicone. problem solved.
rallyracereric
I take it your old motormounts from the Pinto are shot or non-existant. If the local parts supplier cant get them, try Energy Suspension. They might have aftermarket ones or something that will take little fabrication.
On my 8th Pinto and counting!
You MUST use a 2.3 L Pinto oil pan and pick-up.
Pinto_dude
I'm putting an engine from an 82 mustang into a 74 pinto. they use different moter mounts. how can i solve this problem? also, is there anythng thing else i might be forgetting? i'm a new to working on cars and any help would be great. thanks
