80 pinto original
Date: 08/04/2019 10:45 am
Date: 12/24/2016 04:13 pm
1979 hatch needed
Date: 05/13/2018 08:52 pm
Date: 12/09/2018 06:59 am
Date: 11/29/2018 10:26 am
Date: 02/10/2017 09:30 am
Date: 10/26/2020 03:24 pm
Wanted hood hinges
Date: 02/17/2020 05:30 pm
Date: 09/01/2017 07:52 am
  • Online today: 2,457
Windshield Swaps - What Will Fit?
Started by dave1987, February 28, 2010, 10:48:41 PM
Fred, your glass looks like the glue in type, it must have been replaced at some point in time.
My 73 Wagon's windshield gasket is identical to my 78's. I've never seen a "gasket" that flat around a Pinto windshield before!
I have verified valuable information on the windshields regarding 1978 model Pintos!!!!!
For those of you looking for 78 model windshields, there are TWO types used in 1978...
For cars produced BEFORE 06/78 (June of 1978), you will be using a gasket type windshield.
For cars produced AFTER 06/78, you will be using the larger windshield which is held in place by sealant.
The late model 78 through 80 windshields are more readily available than the early model windshields that use the gasket, thus they are cheaper.
I called every glass shop here in the Boise valley in Idaho and I got the last gasket type windshield here. We really need to get these things reproduced!
I dont have all the molding on, was getting ready to paint. You can see gap in bottom strip it had about a 3/16" gap all around molding. I don't know what year glass is for but the car is a 73.  Fred   :)
my understanding is that a 79 -80 will work on a  older one as you stated being glued in.  but that does not meen the 71-78 winshield will fit the 79- 80  model even with the gasket.
The 79 winshield frame is a little different than the early cars at least on the inside in order to mount the interior trim.  There are small "slots/tabs" formed by an extra strip of metal spot welded to the inner window frame.  The "slots/tabs" are about 1/2" deep and 1/4" high.  The inner trim clips to the edge of these "slots/tabs".  There are probably more details that I am not remembering.  I suspect this extra strip of metal would need to be removed (or at least flattened) on a 79-80 car in order for the 71-78 gasket to sit flat on the interior.
Thanks for compiling the interchange details.  Opens up some interesting options.
Been doing some research on the forums about late model (79-80) Pinto windshields vs. early model (71-78) Pinto windshields. Here are my findings:
79-80 model windshields are larger than early models. They are glued and sealed into place instead of using a gasket like early models use. From my understanding, there is "trim" that goes around the windshield on the outside and the inside, simulating a gasket for a smooth appearance.
71-78 model windshields are smaller than late models, and are sealed and secured by means of a gasket.
Now the fun part. a 79-80 windshield CAN be used in an early model car (71-78), but MUST be glued into place. A 71-78 windshield CAN be used in a late model car (79-80), but MUST be accompanied by the gasket.
From my research, the window frame of ALL model pintos is the same, the only difference is the size of the glass, and how it is secured to the car.
And finally, if I understand correctly, if you want to use 79-80 glass on and early model car, you will want to have the outside "windshield seal simulator trim" in order to put your chrome windshield reveal trim on the car and have it appear stock.
UPDATE: Correct gasket type glass for 71 through 06/78 model pintos is domestic windshield 774 glass. Just ask glass shops or suppliers if they can obtain a domestic 774 for you!
If anyone else has any helpful info on this topic, please contribute, it will be nice to have any and all information centralized in one post.
