Date: 03/25/2019 09:02 pm
Date: 02/28/2018 09:37 am
1600 CC WATER PUMP
Date: 06/02/2018 09:13 am
1978 ford pinto carb
Date: 02/04/2018 06:09 pm
77 pinto
Date: 08/22/2017 06:31 pm
Pinto Parts for sale
Date: 06/19/2017 02:01 pm
1978 fuel sendng unit
Date: 05/27/2020 09:54 am
Date: 08/13/2017 02:01 pm
Parts Parts Parts
Date: 09/08/2018 03:13 pm
  • Online today: 630
  • Guests: 531
  • Total: 531
C4 Identification?
Started by Sherman, December 28, 2004, 04:32:17 PM
WVBobcat77
Sorry,
Can't help with that, I'm not in to V8's only 2.3!!
Bill in WV
1977 Bobcat
1978 Pinto - V6 Sedan
Sherman
Hi Bill-
I don't know if I made this clear, but I'm sure it IS in fact a C4. I know there were several made, and since I have to get a flywheel for it, I need to figure out which flavor C4 it is, so I can get the right flywheel (164 or 157 tooth)...
From there I have to figure out if it's 28.2oz or 50oz. balance, and if it will even WORK with my 351W...
Thanks
Paul
WVBobcat77
Count the bolts holding the fluid pan on.  If it's a C4 there will be 11.
Hope this helps,
Bill in WV
Bill in WV
1977 Bobcat
WVBobcat77
Hope this helps,
Bill in WV
Bill in WV
1977 Bobcat
Sherman
I was given a C4 trans a while ago that I plan on using for a 351W swap. The bellhousing fits the block no problem.
I am missing the flexplate, though I do have the trans and torque converter.
Here's my question...how can I *positively* identify what I have for a C4? Apparently there were several, and I need to figure out what I need for a flexplate in terms of how many teeth. It *may* even be out fo a Mustang II, which would be great for my application. There are numbers all over the trans, but I don't know which ones identify what the trans actually IS.
The shaft has 26 splines, and there are 7 bolts holding the bell onto the trans. The filler is on the bottom, where the pan bolts on.
Any idea how I can definitively tell what I've got here?
Thanks
Paul
