1980 cruising wagon ralley
Date: 07/12/2019 01:41 pm
Date: 02/03/2018 11:28 am
2.0 Cyl Head1973
Date: 11/29/2018 12:51 pm
Oddsnends
Date: 12/20/2016 10:52 am
Date: 10/27/2018 03:30 pm
Date: 08/22/2018 09:23 am
Date: 12/04/2018 07:40 pm
pinto wagon parts
Date: 12/19/2019 01:43 pm
1978 Pinto Wagon V8
Date: 04/28/2023 03:26 pm
  • Online today: 531
  • Guests: 525
  • Total: 525
1978 pinto runabout almost done.
Started by Oddzball, February 22, 2010, 11:21:50 PM
That shouldn't affect everything else. The best thing to do is to see what is getting power.  For the radio remove it & using a 12 volt test light or volt meter check the connector with the yellow wire. That wire is 12 volt switchable, so when the light is grounded it should turn on when you probe the plug. You can check at the fuse box as well to see if there are any issues. I would remove the fuses themselves & probe all the terminals. Be sure to do this one at a time so that you don't mix up the fuses since they are different ratings.
Oddzball
Ok, so I took the pinto for a test drive...
Had to fix a fuel leak, cross threaded the line where it goes into the pump to carb.
Replaced that.
Couldnt get my accessories to work.... radio wouldnt turn on, no interior lights... pulled the gauges and found that the cluster with the circuit printed on the back had crumbled to dust.
Well, pulled the cluster out, minus the speedo, which is analog... so no I have the speedo, but no fuel gauge, and still no interior lights, radio or horn..
I can drive it, but it annoys me...
What could be wrong? Something witht he fuse box that would make all this bad? All the exterior stuff works, IE turn signals, lights, reverse light... wipers.... heater fan...
I know I need a new gauge cluster, but does all that other wiring run through that circuit board as well? The radio? Horn?
I'm glad it all worked out! Congratulations!!! I hope you have fun with her! ;D
Oddzball
HA! DONE! Unless I have any major problems should be driving this weekend.
4 months is nothing.....Ive been trying to put a V8 Pinto together for 25 years. Keep the faith.
Glad to know you didn't actually give up!
Oddzball
Ok folks.. 4 months later.. and in the motor goes. everything is put back together, just need to do a little wiring work... annnnd find a new damn radiator... :(
But overall, considering how incredibly slowthis has been going, I'm not super concerned..
Pics are...
Oddzball
Sad thing is I almost gave up on this car.
I just couldnt get the darn bolt out, had trouble getting my friend lend me a hoist to get the motor back in, and in general no help from anyone really.
I even put the thing on craigslist I was so distraut.
I really hope I can get this car out and on the road. If only my friend wasnt so stingy about his darn hoist.
Oddzball
I drilled the bolt out. Easy-out didnt work.
Now  I need to rethread the bolt hole, but i didnt damage the hole as far as I can tell.
Not to mention the post on the drivers side of my carport ::)
I couldn't swing the real stuff, I got the stick on 3/4 chrome from Autozone, $13.99 for 13 feet.
She's cute as a button, Oddz! I do love the 78's. Hope you're on the road soon!
rctinker
1977 Crusin Wagon when I was 16
YAY!!! That bolt was probably the biggest bugaboo of the whole project!!! Hopefully it's smooth sailing from now on!
BTW, If I were you I'd keep the bodyside molding. It gives the car a classy touch, and it REALLY does protect the sides a little from shopping cart contact, trash can contact (ok that's me! lol), etc.
Oddzball
Alright, got the bolt out, now just gotta drop the motor in.
Oddzball,
I had that same problem with the bodyside molding inserts on my '79 Continental Mark V.  Assuming you have the pieces that have popped off, I found that a silicone adhesive works well for holding them in place.  Hope this will be of some help!
Oddzball
Yeah well, It is a little upsetting I will admit. I have had the car for 6 months, and its been sitting for so long I think I might have to buff the paint to get back the old shine.  Also those crome door guard strips on the side? Well, in the center they have this rubber part that popped off, probably due to all the hot/cold changes here in arizona over the past few months. I would like to just remove the door guards but I dont want to have to do body work to fill in the holes where the crome goes.
Oddzball
Yeah fun to drive. Gotta replace the tranny lines and a few minor things as well while the motor is out. I figure why not. Would be a lot more work to do the tranny seal and lines once the motor is back inside, so it is kinda a premptive strike.
Great progress! Love the paint, she should be super fun to drive once finished!
rctinker
Oddzball
Well engine is almost done except that stupid busted bolt for the fuel pump. SHould have it out by the end of the week. Oh and debating if i should put the Air conditioner back on. Worked when i took it off, but will need to be converted..
Oddzball
Poor car sitting out here getting dusty.
Oddzball
Started putting it all back together..
Oddzball
Working on cleaning up old parts like intake and exhaust. all the brackets. Did a lot of painting and little detail work on the engine.
Oddzball
Spun a crank bringing it home from tucson. So rebuilt engine. New everything except the block. Even sprung for a new head.
Oddzball
Ok thought I would load the picks of my pinto, it is rust free, beautiful paint (just dusty) and almost have the motor done to go back in. Interior is the hunter green with yellow checkered seats.
