77 Caliper Bolt
Date: 08/21/2018 04:02 pm
Crankshaft Pulley
Date: 10/01/2018 05:00 pm
Date: 08/30/2021 03:20 pm
Racing seats
Date: 10/24/2019 09:41 pm
windshield
Date: 04/14/2018 08:53 pm
Date: 10/24/2018 07:41 am
Date: 08/01/2018 01:27 pm
1980 Pinto Wagon
Date: 02/29/2020 07:01 pm
Date: 08/26/2018 06:35 pm
  • Online today: 447
  • Guests: 368
  • Total: 368
crank pully timing marks
Started by tim1223, December 25, 2004, 10:54:16 AM
jcbugs
Good one Turbo, I always forget the little things (even though it's not so little when you do that). When your at TDC your piece of wire, I use a screwdriver but you have to be careful that you don't get it jammed in the cylinder, will come in contact with the piston almost immediately after going in the spark plug hole. At TDC your piston will be all the way at the top of the cylinder, 180 off is just the opposite, all the way at the bottom.
That sounds like a good whay to start. BTW to locate your TDC remove the #1 spark plug and put a peice of stiff wire in the hole. turn the crank untill you can feel the piston, through the wire just starting to go down in the hole. Make sure you dont have it 180 deg off........... :o
jcbugs
Welcome to the Forum, I own a 78 with a 2300. What I did was, set the crank pulley at 0 deg.
set the cam to the mark on the pulley, set the distributor on #1 spark plug. Start the car, and then with the distributor vacuum line pulled and plugged, I set the timing with a timing light to 20 deg. BTC.
tim1223
hello all,        I have a 1977 2.3 liter pinto.  I just rebuilt the motor and I'm have trouble timing it.  The problem is that I don't know what degree to set on the crank pulley.  my Chilton's and Haynes manual say to look of the engine decals for the exact degrees, but the decals have been taken off.  The old mark on the pulley is marked at 20 degrees btdc.  This pulley is the double belt type.  Does anybody know what the correct mark is suppost to be at.  Any information would be a great help.                           THANKS TIM
