Date: 04/04/2020 09:38 am
Date: 07/10/2016 10:17 am
Date: 02/18/2017 04:41 pm
Mallory Unilight dist 2.0
Date: 10/25/2019 03:44 pm
Date: 07/20/2018 03:00 pm
Date: 01/30/2017 01:48 pm
Front sway bar frame brackets
Date: 07/13/2017 01:05 am
Date: 04/13/2017 04:56 am
Bumpers
Date: 07/06/2018 04:47 pm
  • Online today: 134
  • Guests: 112
  • Total: 112
A few N/A HP questions...
Started by Pale Roader, February 04, 2010, 08:49:34 AM
Pinto Pro
Pale Roader
Heh... you guys have me a bit wrong on this. I'm NOT thinking ov doing this myself, i was just looking for some input on the N/A potential (efficiency) ov these engines. I've been talking to Honda guys and was just wondering how the lil' (or "big" rather) 2.3 stacks up. My Pinto is going to be a stock cammed, stock headed 2.3, with custom headers, race exhaust, bigger carb, maybe an intake, maybe a chopped head (i'll clean up the ports if i do this), maybe a stock roller, etc. Nothing i cant find at a swap meat for cheap. Should give me 120-140HP depending on how far i go. But i wont stick a big cam, big carb, or hog the head, or do anything that will burn a lot more gas. Plus a T5, plus some gears, minus a LOT ov weight, and it should be fun and commute me 100 miles a day with ease.
But then i keep seeing my neighbor's Civic Si... with its 2L I4 making 197 N/A HP stock... and streetable... and probably VERY good on gas (even in that 3000lb car)... and i get to wondering.
Was just wondering if a guy COULD even begin to replicate this feat with a 2.3 base. Like i said, i've always known there was a solid aftermarket for the 2.3, but if its predominantly a racing one, then streetability flies out the window. For instance, there is a pretty decent aftermarket for the big block Dodge now, LOTS ov options for lots ov different directions, but still nothing much for truly efficient N/A power. Small block chevy on the other hand... well, if you can dream it, its probably available.
I should have stated that this is a purely theoretical question. Well, i thought i did, but i type so much it mighta got lost... heh heh... But you answered my question anyways. Any other thoughts...??
I agree with pintosopher, 200+ hp is a stretch without a turbo.  I'm not sure how much hp my 2.0 had, it had forged internals, 2.3 rods, ported head w/ big valves, hot cam, 4 barrel holley, mallory unilite AND nitrous. Maybe 200? But drivable? Not really. The cam had a lot of lope to it and even with a 4 speed it was a pain to drive in slow traffic.
My V8 is an '89 5.0 HO with the roller cam, runs on 89 octane, doesn't overheat, idles nice and smooth and will turn the car sideways in second gear.
My .02, 4cyl + turbo = 200 streetable hp. (and decent gas mileage)
Stock V8, 250-300 streetable hp and a blast to drive!! (gas mileage, mmmm, not so good! Can't keep my dang foot off the floor!!)
Quote from: Pale Roader on February 05, 2010, 05:24:47 AM
I've been to both sites and dont find a lot ov info specific to my query. But from there and a few (many) other threads about this i gain gather that i'm looking at a heavily modified stock head, big cam, aftermarket internals (but a stock crank?), intake, carb, good header, race exhaust, hot ignition, big compression, etc.
Streetable remains, as always, in the opinion ov the driver. But i guess this idea (a 200-240HP N/A 2.3) would be about in the same range ov characteristics as say a 500-600HP 350 V8...?? So i guess how easy it would be to live with would have a lot to do with the amount ov aftermarket technology available for it. One could build a pretty damn serious LS1 350 and still have a very streetable engine, but with an AMC 360? Not so much. I figured the aftermarket for the 2.3 was pretty vast, but it seems its still mostly in the realm ov old-school technology, or all race.
Sounds like it would be a very impressive build to get 200HP from a stock size 2.3 and still see SOME kind ov mileage or driveability. Probably impossible to get 240 without race gas or stroker?
What about thinking outside the box (if i was still hung up on this idea)? like that Volvo DOHC head? Nothin' like some modern tech to change the parameters. Is there a good aftermarket head that isn't a full race piece? Something like the nicer entry level street heads for the V8's...?? Something with a more modern port/chamber design...??
I've weighed in on this topic before, and it seems we get nowhere! The Lima 2.3l isn't going to make 200 HP N/A unless there is some serious internal mods to deal with RPM and Stresses from harmonics. Then you have to deal with Flow design of the Heads out there. Aftermarket EFi would clean up the driveability and add HP & Cost! There is no variable valve timing to enhance the range of power- This isn't V-Tec!
Look at the Acura Integra type R, BMW E-30 M3 and you are looking at a 10K dollar motor when new to the marketplace years ago.
A Cossie YB twin cam ford 2.0L is over $8 grand without much of the ancillaries to install. It will bolt right up to the stock 2.0L motor mounts, and trans bell housing. But these are rare in the states.
Even the "poor mans " twin cam  Aka Ford Duratec 2.3 has some serious cash outlays to make 200 N/A HP. And you still have to make up a Sump for the Pinto crossmember issue.
Makes that turbo swap or V8 Look much more affordable, Eh?
  We get what we pay for, and that's the Bottom line!
Pintosopher .. Reality Bites!
wedge446
You could always nitrous.  Build it with good parts, forged pistons, good rods/bolts and with good timing control you`ll have a very streetable engine with the added HP at a flip of a switch.
Pale Roader
72pair
The jump from 140hp to over 200hp is a serious one. You'll need high compression, large cam specs, well worked cylinder head, induction, and exhaust. Really not a streetable package considering the rpm range you'll have. Check out Esslinger Racings crate engines. They put out a little over 200hp for a starting price of $7499. Turbo or v-8 is starting to sound better eh. My $0.02. JT
pintokite
try racerwalsh.com they have a 5 page tech. sheet on building a 2.0 and 2.3 . I've used some of their info. just a suggestion.
Pale Roader
I should also add that i know how cheap stroking a 2.3 can be, or how much easier boost or a V8 can be to live with than a N/A screamer. Just looking for some perspective on the 2.3's N/A capabilities and costs.
Pale Roader
Well, ever since ditching the V8 idea for the time being (i need a good on gas car, well... i need a good on gas car thats fun) i've been thinking a lot about what to do with 4 cylinders. I've come up with a couple gems, but first, i need some perspective, hopefully someone here can help me out.
What would it take to get an honest 200-240HP out ov a naturally aspirated 2.3, WITHOUT increasing the displacement beyond the usual rebuild overbore? OR using race gas? (91 octane limit) With the aftermarket available for these things i know its possible, or more even, and i know it will have to rev, but at what cost? Thats the number stuck in my head right now. Are we talking aftermarket head? crank (for strength)? block? or can this level be achieved with (heavily) modified stock-ish long-block parts? I assume it would need an aftermarket manifold, cam, internals, induction and exhaust, maybe picking the best stock head for porting and going to town with the die-grinder, etc.
How driveable (in a 5spd stick car) would such a creature be on the street? for a commuter (yes, i said it)? How reliable?
(heh heh...) And what kind ov gas mileage would it get when NOT driving like a tool...?.??
These are serious questions. I was looking at just simple bolt-ons (no cam, no big ports, no honkin' carb, etc.) for an easy 120-140HP daily driver type car, but then something else popped into my head and wont leave. I dont know enough about the serious HP 2.3, but some here do.
