Date: 04/12/2017 06:57 pm
door sills
Date: 03/14/2020 03:20 pm
73 Runabout
Date: 11/20/2017 03:19 pm
Date: 05/28/2017 03:20 pm
Intake manifolds
Date: 03/06/2021 03:04 pm
Date: 08/08/2017 01:44 pm
77 pinto cruz. wagon
Date: 06/15/2017 09:18 pm
MISC PINTO PARTS
Date: 08/27/2017 10:23 am
72 Pinto
Date: 03/07/2019 12:07 pm
  • Online today: 531
  • Guests: 201
  • Total: 201
Throttle Cable (ideas) ???
Started by quickrick, December 14, 2004, 11:47:25 AM
quickrick
Thanks for the suggestions. I've decided to go the dirt track route, ie... two heims and a rod.
TYDEKE MOTORSPORTS
Tricky Ricky Chop Shop
(740) 701-2908
Chillicothe, Ohio 45601
Tobey
Quote from: quickrick on December 21, 2004, 08:17:29 PM
Unfortunately a ball is not the problem, hooking up the throttle to the carb is no big deal. As you probably know the factory carb linkage connection is in the front. The motorcraft is on the side. This causes the stock throttle cable to be about 4 -5 inches to long.By using the stock cable in stock form it would have a bend in it. I am looking for suggestions to change too,etc...
Rick
Got it.  I'm actually not familiar with the stock setup; I bought my Pinto as a prepared race car and use dual Webers on the 2.0.
As long as the bend isn't sharp, there shouldn't be a problem.  Try routing it a couple different ways to take any sharp bends out of it.  As Turbopinto72 suggested, a custom bracket might be needed to hold it in the right spot.
If you have to go to a new cable, Summit and Jegs, and I'm sure many other places, stock universal cables made by Lokar (Try Summit part no. LOK-TC-1000U36 for a 36" cable).  That's what I have on my race car and it works fine.  The fittings are removeable so it should be easy to shorten it if you need to.
Good luck.
Make a longer ( arm) that bolts to the manifold and will extend the cable that 4" longer. Its kinda what I did to my clutch cable only in reverse.
quickrick
Rick
TYDEKE MOTORSPORTS
(740) 701-2908
bricker4864
If all you need is the ball, just go down to NAPA/local parts store. It was only a few bucks for an assortment pack. If you know what size you need (ball diam & thread) they had a bunch individually also.
Tobey
Quote from: quickrick on December 14, 2004, 11:47:25 AM
I have installed a motorcraft (Holley) 2 barrel carb on the 2300. I need to come up with a throttle hook-up, any ideas???
Little more info, please.  Does the cable reach the carb, you just need a different connector?  Or do you need a whole new cable?  If the cable reaches, what does kind of fitting is on the end of the cable?
If all you need is a little ball for the cable to snap on to, go to www.summitracing.com and search this part no.:  hly-20-2
quickrick
TYDEKE MOTORSPORTS
(740) 701-2908
