77 Caliper Bolt
Date: 08/21/2018 04:02 pm
Date: 09/22/2020 11:33 pm
Free 2.0L Valve Cover
Date: 01/03/2023 04:27 pm
1978 Pinto Wagon V8
Date: 04/28/2023 03:26 pm
Crankshaft Pulley
Date: 10/01/2018 05:00 pm
95 2.3l short block
Date: 03/18/2017 04:54 pm
oldskool787
Date: 02/12/2017 12:42 pm
Date: 10/14/2019 08:24 pm
Pinto Fiber Glass Body Parts
Date: 01/06/2019 06:53 pm
  • Online today: 246
  • Guests: 222
  • Total: 222
Gas milelage
Started by dowty71, January 18, 2010, 05:03:15 PM
don't forget to check the valve lash to!
 I'm getting 16 in town and 24 highway consistently with my 76 pinto (2.3/4spd/3.00 gear)
Thats with a bigger engine.  Id think with a 1.6 or 2.0 engine should do better, plus the earlier model pintos are lighter.
I think you should check out the fuel pump and the condition of the spark plugs, plug wires, cap and rotor. Might also consider getting a GOOD coil and not a cheapie. Maybe an MSD? Check timing and points also. A point-to-electronic conversion would be an excellent idea.
Quote from: Carolina Boy on January 18, 2010, 09:04:53 PM
Had the car been setting a long time?
Get a tuneup and replace the fuel filter, may even need the tank flushed.
PS: Bobcat, you got my message?
No sorry CB I hadn't gotten any mesages whats up? if you need directly email me it would be easier since im not on here like i used to be
78txpony
A complete tuneup on a newly purchased car is almost mandatory.
Check the colors of the spark plug tips.  If black, it is running way too rich.
Check vacuum hoses / caps for leaks and breaks.
Carb might need a rebuild, too (a fairly easy task).
Choke working right?  Fully open when warmed up?
Mileage should be closer to 18 in the city.  I get 20 with my '78 2.3.
-Rob Young
1997 H-D Sportster
What motor/trans does it have in it. does it run rough, smell like a lot of gas at the carb? Timing off maybe? clogged carb. leaking jets? could be many things more details would be helpful
dowty71
Hi. I just got my 72 wagon and it is not getting much more then 10 miles to the gallon. What could be some of the problems causing this? It only has a little over 75,000 miles on it . If any one has any ideas please call me at 937-339-7177 and I will call you back. Thanks Mark.
