turbo 4 cyl and aod trans
Date: 12/14/2019 04:55 pm
1977 Pinto Cruizin Wagon
Date: 04/11/2024 03:56 pm
Date: 07/08/2017 08:53 pm
Intake manifolds
Date: 03/06/2021 03:04 pm
72 Pinto parts
Date: 11/14/2019 10:46 pm
rear hatch back louvers
Date: 04/18/2017 12:44 pm
Looking for a few parts - TIA
Date: 02/19/2023 12:18 pm
Automatic transmission
Date: 02/13/2021 02:52 pm
74 Pinto Rear Side Lights
Date: 02/18/2017 05:47 pm
  • Online today: 600
  • Guests: 430
  • Total: 430
wiring diagram 79 pinto 88 turbo coupe 2.3
Started by ei321, January 15, 2010, 09:47:20 PM
Well, let me say first off this is a tough one.  A lot of people have said to get the Murkur harness since it is designed as a "stand alone."  Others recommend I believe it was the '86 harness as second choice.
I didn't follow either recommendation.  My T/C was an '88 also with ride control and ABS.  I completely pulled every bit of the harness and laid it out on the ground (It must weight about 35 pounds by the way). Then I spent a LONG time disecting out what wasn't needed.  I'll bet I had over 50 hours in that process!  All the stuff around the dash center area and steering column really gets jumbled (see attached picture).
One thing I did do was keep the T/C fuse block and basically wired it as a separate entity to the battery.  I also used the T/C steering column, retained the cruise control and intigrated as much of the dash gauges as I could.
While I have not found a wire I shouldn't have cut, I still have about 15 or so wires I'm still trying to figure out if I can get rid of or not.  My car started on the first go, but I have had driveabilty issues - whether they are wiring related or not I'm still not sure.
All the best, but frankly there is no simple "do this" process.  It is more of a "journey of discovery."
Tom
ei321
i have seen many people asking about help on a wiring diagram for the 2.3 swap into the pinto and i cannot find anything and i just dont know where to start and what to do sorry for the repeated question just need advice thanks
