Needed, 2.0 or 2.3 motors
Date: 09/30/2018 07:47 pm
Date: 09/22/2020 11:33 pm
Date: 09/12/2018 12:33 pm
74 Wagon Interior
Date: 01/22/2017 06:38 pm
Date: 07/08/2022 11:51 pm
1977 Front Sump 2.3 Oil Pan
Date: 09/14/2018 11:42 pm
oldskool787
Date: 02/12/2017 12:42 pm
1979 Pinto Rear Bumper
Date: 03/26/2021 03:26 pm
Date: 10/01/2020 02:00 pm
  • Online today: 447
  • Guests: 405
  • Total: 405
Adjusting the choke on a 79 2.3
Started by pintoguy76, January 08, 2010, 10:22:25 PM
That is correct. You push the pull-off rod till it stops (with a screwdriver), then adjust it properly with the torx screw at the end of the vacuum fitting. Check out those rebuild instructions, it explains the procedure.
78txpony
The allen head bolt at the end of the pulloff is an adjustment screw i believe.
-Rob Young
1997 H-D Sportster
pintoguy76
I'll check all that stuff, thanks guys. What does the bolt at the end of the choke pull off do?
Good points 78ts, forgot about doing that while troubleshooting mine. I messed with that thing for to long. but it is nice to have it working again.
78txpony
Quote from: dave1987 on January 09, 2010, 02:01:30 AMAlso check your electrical connection, to the choke, with a multimeter/voltmeter and ensure you are getting 12 (or is it 7?) volts to it. I believe it is 12 volts, since the choke power wire is run from the alternator harness.
Just to clarify, the voltage will be present ONLY when the engine is running..
Is your alternator charging?  The brushes wore out on mine last year and your problem is the way I found out about it.  I am surprised I ran on the battery so long at night in the cold!
Also, remove the choke heater unit and clean the ground contact.
I think the choke pull off is vacuum operated to pull the choke back a little when the engine starts.  Remove the vac hose and use another clean hose on it to zoop on it to see if it pulls off.  If you keep sucking air through it, the diaphragm is damaged.
-Rob Young
1997 H-D Sportster
Here are the rebuild instructions that come with holley 5200 rebuild kits. It's what I use to adjust everything on my carb.
http://www.docstoc.com/docs/13763751/5200-Holley-Carbuetor-Kit-Rebuild-Instructions
I use drill bits to get the correct adjustment gaps.
pintoguy76
I'm having a problem on my 79, it will start just fine when its cold but let it sit a few minutes and come back and it is a bear to start. Here lately It takes two people to start it. One to hold the choke butterfly open and one to hold the pedal to the floor while cranking the engine. It floods itself. The choke snaps shut.......all the way.....when hot. I'm pretty sure its the chokes fault, not opening soon enough and closing too soon. Also the choke should never TOTALLY close off the air supply should it? Shouldnt there be a 1/16" gap or so between the wall of the air horn and the butterfly when its off and cold? This thing snaps shut. All the way.
How do i adjust all this stuff? There is a allen head bolt in the end of the choke actuator, im sure that needs to be adjusted but arent there SEVERAL adjustments that need to be made for the choke?
This is the electric choke that had a vaccum line on it, there is no hot water choke on this thing.
Help me get this fixed! Im sure my mileage will go up once this is fixed.
