  • Online today: 344
  • Guests: 253
  • Total: 253
Charging system wiring
Started by stinsonj, January 06, 2010, 10:05:07 AM
stinsonj
I just needed to run a wire from the "I" terminal on the voltage regulator to the ignition switch.  It works perfect now:)
Here is a 1986 charging shematic showing that fourth wire from the regulator to ignition switch run circuit.  According to my 74 & 77 shematics, the Pinto uses a ~15 ohm resistor wire instead of the 500 ohms shown in this newer schematic.  The wire colors shown are the same as in the Pinto.  You can ignore the rest of the link.  Make sure your regulator case is grounded also.  Note the 78 Pinto schematic shows "I" circuit not used with the sport option (dashboard ammeter and no warning light), assuming I am reading the schematic correctly.
http://www.rothfam.com/svo/3g/
The 77 Pinto book shows a test of the alternator by unplugging the regulator and temporarily jumpering together the "A" (Y/W) and "F" (O/LB) terminals of the regulator socket.
Operating the car on the alternator alone (no battery) may work sometimes.  It can inject a lot of noise into system and may damage sensitive electronics if any.  I would do this only as a last resort to get home.  The battery acts like a large capacitor and filters the noise out.
stinsonj
I think i kinda figured out why it isnt working.  I was unaware that the alternator needed to be hooked up to the ignition in order to be activated and start charging.  Ill just need to re-do somewiring
stinsonj
It is a brand new regulator.......
Could the alternator not be grounded properly?  I thought that was the problem originally so i grounded the engine block to the frame thinking that would fix the problem but it didnt.  Searching around i found a diagram for a ford alternator and it shows a grounding terminal.  Do i need to ground directly to this terminal or should grounding the block to the job?
is it the origonal regulator? the origonals were mechanical and can stick. the contacts inside can stick and not work.. its a inexpensive part to replace and id suggest getting the newer style as it will keep the voltage smooth. swapped mine and all my electrical seems to work better to include brighter lights at night.
stinsonj
I have a 1975 2.3L pinto engine that runs great but is only running off of the battery.  The alternator seems to be hooked up correct: Larger wire running to the battery side of the starter solenoid, the other two wires running to the voltage regulator.  On my voltage regulator, i have the two wires from the alternator and one from the starter solenoid (one terminal doesnt have a wire hooked up to it).  I had the alternator tested at NAPA and it passed so that shouldnt be my problem.  Im kinda confused cause i figured that if the bat cabled from the alternator is connected directly to the battery side of the starter solenoid, then i should be able to unhook the battery while the engine is running and it should continue running off of the alternator??  Can anyone provide some insight or a wiring diagram?
I should add that i had the bat wire from the alternator run through an aftermarket ammeter which wasnt registering anything.  I thought maybe there is a connection problem in the ammeter so i bipassed it and ran directly to the solenoid.
