Date: 03/17/2019 10:15 pm
WANTED Hood Prop Rod
Date: 01/17/2017 02:47 pm
Date: 09/17/2024 12:35 pm
1979 hatch needed
Date: 05/13/2018 08:52 pm
pro stock front end
Date: 06/28/2019 07:43 pm
Looking for front seats
Date: 08/10/2021 09:54 pm
Date: 03/21/2017 07:47 pm
1970-1973 Gas Tank/Blue Dash
Date: 02/07/2019 11:57 pm
  • Online today: 344
  • Guests: 253
  • Total: 253
5 speed manual in a pinto?
Started by stang2, December 05, 2004, 06:59:31 AM
Use the same flywheel,clutch, pressure plate and cable. You will need more length on the cable to get it back to the through out arm. I nubolted the cable at the fender mount, added about 4 inches to the mount bracket and bolted it back up. this will extend the cable further back. Also, you may need to grind a little on your rack mount on that side.
CHEAPRACER
A mustang drive shaft fits perfect with no cutting, 79 thru early 90 something. Make sure you get the small u-joint model or you'll have to by a hybrid u-joint (big deal 20.00 at Auto Zone).  The crossmember can be redrilled but right on the edge. Someone else will have to explain the clutch and cable. I used the hydraulic set up and the Turbo Coupe clutch.
stang2
SVOwagon
I guess I should have asked this first...what year car and is it a 2.0 or 2.3 4cyl?
80 2.3 EFI Turbo Pinto Squire Wagon
91 Mustang LX 5.0 (93 Cobra clone project)
82 Mustang GT (built 460)
89 Mustang LX coupe (built 302)
83 Ranger
http://www.cardomain.com/ride/2167062
stang2
Will I have to change flywheels?  Can I use the same clutch setup?  How much longer or shorter is the 5 speed than the 4 speed from a pinto?  Thanks
SVOwagon
I have a 5-speed in my ride. D-shift will have to be cut, trans mount will have to be modified, and hole in the trans tunnel will have to be opened up in the front to clear the shifter. May have problems with cable working with fork.
83 Ranger
stang2
Anybody ever put a different manual tranny in a pinto?  What works and what doesn't?  How bouta five speed from an 80's mustang?  Looking to try something new.  Thanks for your replies.
