Date: 10/24/2018 07:35 am
Cruiser Dash Gauges
Date: 12/04/2016 11:50 am
Date: 03/18/2020 01:30 am
72 Pinto parts
Date: 12/04/2018 09:56 pm
'79 Ford Pinto, Green,
Date: 10/29/2019 11:50 am
$300 Pinto for sale
Date: 04/19/2017 10:24 am
Tire needed p185/80r13
Date: 12/31/2017 09:08 pm
turbo 4 cyl and aod trans
Date: 12/14/2019 04:55 pm
Date: 09/15/2019 12:28 pm
  • Online today: 489
  • Guests: 202
  • Total: 202
v8 t5 bellhousing in pinto ???
Started by Pinturbo75, December 18, 2009, 02:05:37 PM
yes, ive seen that. chris has a ton of good info. he's kinda like a dictionary.... nice guy.
Mike Modified
Have you seen this http://rothfam.com/svo/belladapter/ comparing the Stinger adapter to the Canfield?  Plus has some install pics and description.
Quote from: Pinturbo75 on December 18, 2009, 03:39:23 PM
yeah, im hoping so. i bought what was supposed to be a standard 2.3 spec aluminum flywheel and 3+ clutch kit and it turned out to be a 5.0 kit made for a 2.3 crank. iwas a little jilted at first but the more i thought about it the more it makes sense to try to use it. i have everything except the adapter plate and i only paid 400 for the whole kit and its new in the package. it costs nearly 800 off the shelf at spec. we'll see how this goes and ill try to update anythig i find on the install.....
Donm't forget to take pictures and let us know how it went.
this flywheel and clutch setup is not the same size as the 2.3. the 2.3 turbo is a 9 1/4 inch clutch. the v8 setup is 10.5 inch. so to use it i have to use a 2.3 to 5.0 adapter and v8 bellhousing.
skunky56
77 Starsky/Hutch 2.3 Turbo A4OD Sunroof
78 Wagon V6 C3
with your 75 i really think it will fit fine. the early models where a little tight but your tunnel is wider. i put the t5 out of a mustang in my 71 had to do some mods but from what i see on the site with later models its purty good fit.
looks like im going with a v8 clutch setup in the turbo pinto and am curious to how much work is needed to get the v8 bell in the pinto? this is going into my 2.3 turbo 5sp car. thanks steve.
