78-80 Windshield
Date: 10/29/2021 03:11 pm
Date: 10/24/2019 01:43 pm
1971 2 lt Cam
Date: 10/10/2020 06:27 pm
Date: 01/19/2021 03:56 pm
Date: 12/10/2016 04:11 pm
77 Wagon rear hatch
Date: 12/04/2019 05:57 am
Date: 07/17/2019 05:23 pm
1980 Pinto-Shay for sale
Date: 07/07/2016 01:21 pm
Clutch pedal needed
Date: 01/11/2024 06:31 am
  • Online today: 600
  • Guests: 275
  • Total: 275
5.0 Bellhousing
Started by Pangra74, December 18, 2009, 01:55:50 PM
turbo74pinto
Quote from: smallfryefarm you need to watch some time in the 90s the went to longer input shaft and the bells are 3/4 deeper to acomidate.
/quote]
im pretty sure the first year for this was in 94 when they did the body change.
bob
Pangra74
I'm going bsck a few years, but I remember pulling a 289 from a '65 Mustang and swapping in a '69 302. We used the 289 flywheel....bad idea....ran like a washing machine out of balance and had to get the correct 302 flywheel. Of course I was 18 at the time!!
Joe
1974 Orange Runabout
Thats what im thinking CB, im definatly no expert just what i think would work.
Sorry, but I got to ask one more time to make sure I heard right.
My engine: 1967 289 (late year production, 28 oz.)
I need to get together a 1989 Mustang's 302, T-5, bell, pressure plate, clutch, throwout bearing and clutch cable. Stir together and enjoy rumble, right?
In my case, would it just be easier to keep the bell fly, clutch, pressure, use a hydro throw out and use an adapter to install the T-5?
sorry CB i usually get confused when i start talking  ;D Yes the bell and trans should work and i purty sure you have a 28oz motor. The fly wheel and balancer is what you really have to watch when going from early to late.
 ??? ??? You talking flywheels? Now i'm confuzed, again :lol:
Wasn't the late 67 289 the same as the 68? I have brainfreeze!
you can use the 89 trans bell clutch, just be sure to use the correct flywheel i think it is 68 to 80 use external balance of 28oz and 81 later use 50oz, dont mess up it will beat the bearings out rather quickly but the the bell trans and clutch should work. I may be all jacked up on this to going by memory.
Was there any balancing issues? I heard something about the internal vs external crank balance. Remember, I am using a late 67 289.
If this is not an issue then I could take the 1989 bell, clutch, plate and trans and bolt to my engine, Right???
pintoracer02
I have the same setup fits but its tight. Mine came from an 89 mustang. If you plan on getting a stage 2 or 3 clutch its cheaper to build one from ebay. get a high pressure pressure plate and i bought a ceramic puck disc for about 75 bucks new.
Bass Ackwards
i used the 89 bellhousing in my 71 but you need to watch some time in the 90s the went to longer input shaft and the bells are 3/4 deeper to acomidate.
Pangra74
I've been going over the V8 swap threads and have a question. I have the Mustang II motor mounts, exhaust manifolds, and oil pan coming from a donor car. I found plenty of V8 bellhousings on Ebay. Should I use the 87-93  Mustang 5.0 T5 bellhousing, flywheel setup for the Pinto? I have a 74 with the larger engine compartment and want to avoid clearance problems.
Joe
