Date: 07/20/2018 03:00 pm
Pinto Fiber Glass Body Parts
Date: 01/06/2019 06:53 pm
Date: 12/31/2017 11:14 pm
Date: 09/01/2017 07:52 am
77-78 front grill
Date: 04/07/2017 12:35 am
1980 pinto wagon for sale
Date: 12/11/2017 12:13 am
Date: 08/26/2018 06:23 pm
71-71 speedo cable
Date: 07/31/2021 09:04 pm
Hatch needed
Date: 09/10/2017 09:16 pm
  • Online today: 600
  • Guests: 257
  • Total: 257
Interior LED lighting
Started by Pintopower, December 18, 2009, 02:22:51 AM
NICE! Alberto, you amaze me!  ;D
Original74
I thought you were going to control the porthole lights with the audio!
Looking great Alberto, and great advice about the aux. fuse block, been thinking about that myself.
Give a gig Oklahoma howdy to Thomas and Racer X for me.
Dave
PS. Jade gave up her rubber steering joint this summer in storage. Keep your eyes peeled for a NOS one for me please. I just can't put a NAPA part in her. May not even change it since I am not driving her. She's sitting on 00430.1.
Dave Herbeck- Missing from us... He will always be with us
1974 Sedan, 'Geraldine', 45,000 miles, orange and white, show car.
1976 Runabout, project.
1979 Sedan, 'Jade', 429 miles, show car, really needs to be in a museum. I am building him one!
1979 Runabout, light blue, 39,000 miles, daily driver
Pintopower
No its not my elbow! HA! lets just say it will complete the look....
#1. 1979 Wagon V6 Restored
#2. 1977 Wagon V6 Restored
#3. 1980 Sedan I4 Original
#5. 1980 Wagon I4 Restored
...Like i said, I like them.
...and I have 4 Fiats.
Now that's psychedelic with a capital hey man! :afro:
And that would be? and dont say your elbow.  :lol: that is really cool love the look.
Pintopower
Well, I also lit up the cruising wagons port holes! Here is how I did it:
Applied the LED strip to the INSIDE of the trim ring. I don't want anything visible
Installed with the flash
In the dark (photo is unaltered):
Looking through the other port hole:
With both port holes and the under dash lit up, the car is a rolling disco! I have one more thing up my sleeve...
Pintopower
Well the first key is planning. You need to know what you want to add to the car. Install a second fuse panel so that you only need to run a 10 gauge wire from the starter solenoid (and fuse it as close to the solenoid as you can) to feed anything you want to run in the car without taxing any factory wiring that was not intended to run something high draw. You also must know that less is more. Adding wires to a car is always tough to do well. Add them to looms when ever you can and this is curtail when adding relays. In the case of the under dash lights, they draw so little power that the amp clip cant even read the current. The are available on ebay as LED strips and come in MANY sizes. The one I added in the white car is 60 inches. For the blue pinto, since it has a console, i bought two 24" lengths. Here is the switch panel for the blue car:
My trick for multiple low current leads to minimize wiring.
The middle tabs are for the switch and go to, in this case, under dash lights, fog lights and blue parking lights
Here is the fuse panel right when I installed it. Note the large red wire above and the smaller lead for the radio. This was in the blue pinto right when I installed it. The power lead is hidden now but the smaller ones are tucked away but due to geometry are still visible from under the dash.
On the white car (the one with the blue lights shown) could not add my usual switch bank to the under dash since I went to GREAT trouble to make the dash look like an early car. I added the switch to the inside of the center console.
and hid the wires under the carpet
Take your time wiring. Don't use a 12 gauge if 22 will do. Solder where ever you can and relays and fuses are your friends!
So spill the beans, how did you do it??? ???
Pintopower
Ok, I love lights. I love electrical. I love wiring. Well, add those together and you get this. This is just the beginning. All wiring is completely hidden. This photo is unaltered.
