Date: 11/12/2020 08:28 pm
Clutch Fork
Date: 03/31/2018 09:12 pm
Date: 10/26/2020 03:24 pm
pinto floor mats??
Date: 01/11/2017 07:27 am
Pinto or Bobcat wagon wanted
Date: 08/05/2018 10:49 pm
2.0 Cyl Head1973
Date: 11/29/2018 12:51 pm
Lower Alternator bracket
Date: 08/26/2017 05:11 pm
Date: 09/09/2018 03:22 pm
74 & Up Parts
Date: 01/20/2021 03:22 pm
  • Online today: 484
  • Guests: 523
  • Total: 523
heater valve question
Started by dholvrsn, December 16, 2009, 03:30:58 PM
Pintopower
Ok I hope i get this correct. I think the default is "open" with no vacuum so that means when the a/c is set to on or fresh AND the slider is all the way to cold the vacuum is applied to the valve and it  "closes" so that hot water does not flow. Only of those parameters are met will the valve close. I dealt with this on my 74 Pangra with factory air. I figured it out when looking at my 79.
This is the valve you need for 74-80
http://cgi.ebay.com/ebaymotors/NEW-PINTO-MUSTANG-HEATER-VALVE-1965-78-D4AZ18495A-MOR_W0QQcmdZViewItemQQhashZitem518f1845adQQitemZ350293083565QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories#ht_816wt_812
#1. 1979 Wagon V6 Restored
#2. 1977 Wagon V6 Restored
#3. 1980 Sedan I4 Original
#5. 1980 Wagon I4 Restored
...Like i said, I like them.
...and I have 4 Fiats.
This question concerns the temper control vacuum valve on later Pintos with factory AC. The part number is either D3AZ-18502-A or DZAH-18502-A4A. Does the thing supposed to port vacuum to the two outlets when it's slid over to the left cold side or the right hot side? Thanks!
BTW, I had a technically incorrect thought about the  vacuum canister the other day, "I don't want all the vacuum to leak out!"  ::)
