Mustang II C4 Transmission
Date: 07/28/2017 06:26 am
Date: 05/24/2020 08:19 am
Date: 10/25/2019 04:05 pm
front end parts
Date: 03/30/2018 12:48 pm
Date: 05/13/2021 05:33 pm
Date: 12/04/2018 07:40 pm
Date: 07/20/2017 01:23 am
Date: 10/28/2018 08:45 am
Date: 04/13/2017 04:56 am
  • Online today: 642
  • Guests: 168
  • Total: 168
interior lighting
Started by mytxplode, December 05, 2009, 08:59:44 PM
mytxplode
Thanks guys! They're dim, but they work!
It's only good if it works!
Good point Phil! I had issues with some of my cluster lights not working. Some days they would, others they wouldn't.
It turned out to be the sockets the bulbs were mounted in. So I started to stockpile bulb sockets from 70s Ford cars.
The small brass/copper contacts in the sockets tend to wear out and get hairline cracks where the contacts bend at a 90 degree angle on the sides. It's hard to see the cracks, but you can tell if you push down on the contact point. If the arms don't spring back up, the socket needs replaced.
i had a similar problem a few years ago. i had to cleat the light sockets for alll the bulbs and replaced a few light sockets as well  it was very fustrating but that was after i tried  what the others have suggested.(fuses ,wires)
Easy for the dash harnes to not get plugged in all the way.  Worst case pull the dash and check to see if you have power at the dash lights.  if not then work backwards on the wiring till you find the problem.
Check the fuses?
Might also check the wire harness that leads to the cluster.
mytxplode
I put the dash back together yesterday, (79 pony) I swapped out the dash cluster because it wasn't lighting up. This one doesn't either. The wiper knob & heater controls light, but thats all. Ideas from experience??
        Mike  MYTXPLODE
