1971 Pinto (survivor)
Date: 05/15/2022 04:42 pm
Mirror
Date: 04/15/2020 01:42 pm
Date: 08/01/2023 06:53 pm
pintos for sale
Date: 12/11/2018 04:29 pm
Date: 08/03/2017 07:40 pm
Date: 03/25/2019 09:02 pm
oldskool787
Date: 02/12/2017 12:42 pm
1978 ford pinto carb
Date: 02/04/2018 06:09 pm
Pinto Wheel Well Trim
Date: 03/29/2017 11:35 am
  • Online today: 1,972
  • Users: 1
  • Guests: 117
  • Total: 118
  • cbdpxp
T5 swap, flywheel question
Started by yblock64, November 25, 2009, 07:12:42 PM
yblock64
Did not know that either. My '80 was originally a manual trans car that the previous owner converted to a C4 to drag race. The mount for the pedal(s) is still under the dash, so now I only need to find the correct brake and clutch pedals. Thanks for that info, I learn more from this site every time I log onto it. Richard
Be careful about the pedals.  There are early pedals and late pedals.  There are booster pedals and non booster pedals.  I recall someone saying there is a fourth pedal type too.  So, make sure you get the right ones.
Tom
yblock64
Thanks, did not know that. Now even more choices to get everything coupled together.Richard
turbo74pinto
c4 and t5 yokes are the same.  in fact they are the same as the aod also.
bob
yblock64
Thanks guys- After looking at the online parts books from Autozone I found that the clutch for the '92 T5 is indeed 8-1/2", with 10 splines. They also list new clutch cables for $31.99, part# 14803 for '80 pinto. A company by the name of Driveline.com lists new quality flywheels too for less than $75.00. I think Racer Walsh and Esslinger stock  the high strength flywheel bolts and pressure plate bolts. I'm not sure if the driveshaft yoke for the C4 will work with the T5 or not, but a rebuilder of B/W T5s' told me a yoke from Ford big cars from the 80s'(Grand Marquis, Crown Vic) work perfectly and are dirt cheap in salvage yards. Now if I can find a Brake and clutch pedal I'll be able to start on this project. Guess the V8 car will have to wait a while. This 'ol pinto should be a lot of fun after I get the 5 speed installed. It only weighs 2200 #(gutted interior, lots of lightening of parts) has a healthy 2.3 with ported head, A-237 roller cam, adjustable cam sprocket, small crank pulley, header, electric fan and lightweight driveshaft. I'm just getting back into Pintos after an absence of 25 years. Back in the day I had a '72 sedan, 2.0 4-speed with a few bolt on goodies and some good tuning that was FUN!! Man how I loved beating up on those pathetic 2300 cc Chevy Vega rustmobiles, and any other 4 bangers that came along.But I did race a Toyota Celica GT that I whipped in the 1/4 mile but on top end he BLEW by me and ran out of sight. Oh, the memories.....
72pair
Any 2.3 flywheel should work. You have 2 choices. Standard mustangs & pintos used an 8.5" clutch. SVO, turbo mustangs, & turbocoupes used the 9 1/16 clutch. Whichever size, you need the 10 spline clutch disc. JT
turbo74pinto
any t5 flywheel and clutch should be fine.  my t5 is an 87/88/91 blend, with a 74 cable. works great!
bob
yblock64
Well, I purchased a T5 from a 1992 2.3 Mustang along with the bell housing for the swap into my 1980 Pinto. I do not have a flywheel so I was going to buy one along with the clutch assembly. My question is: Do I buy a flywheel from the same year as the T5 trans or will any year 2.3 flywheel work? What about balance issues? Clutch/pressure plate size differences? Thanks
