Date: 10/31/2018 12:00 pm
MISC PINTO PARTS
Date: 08/27/2017 10:23 am
FLOOR PANS
Date: 06/12/2020 07:24 pm
1974 Wiring diagram free
Date: 10/27/2019 06:56 pm
Misc. Pinto parts
Date: 11/09/2019 04:25 pm
Date: 06/28/2019 09:14 pm
Date: 08/05/2018 01:58 pm
Date: 01/23/2023 02:22 pm
72 Pinto Wagon for sale
Date: 12/31/2017 08:40 pm
  • Online today: 535
  • Guests: 505
  • Total: 505
proper timing for a 2.3?
Started by geoff104, October 25, 2009, 05:30:22 PM
72pair
On my modified engines, I usually set timing at 36-38 degrees total mechanical advance. You'll need a dial back timing light or a degreed pulley for this method though. JT
mytxplode
Quote from: geoff104 on October 25, 2009, 05:30:22 PM
Does anyone know the proper timing for a 78 2.3 pinto? It has a racing cam, ported intake and 230cfm holley 2bbl if that makes a difference. Thanks for the help!
Mine says +6.
It's only good if it works!
10* is most likely the best bet depending on what octane fuel you plan on using. That can vary too depending on if the head has been shaved, ect. What Mike means by "pinging" is what some people think is the valves rattling on a pull. Let the engine lug down a bit in high gear like right before you would downshift and listen for "pinging". If it does, you need more octane or less timing.  :)
geoff104
So, I'll set it at 10 and try. I don't understand what you mean by ping though (I've never timed an engine before) Thanks for the advice!
Mike Modified
I would set it at a nice safe 10*.  Drive it hard.  Ping?  No!  Set it at 12*.  Ping?  No!  Repeat +2* until it pings, then back off to last non-pinging setting.
My $.02 for the month.
geoff104
