Date: 02/05/2020 11:06 am
Date: 06/28/2019 09:14 pm
pintos for sale
Date: 12/11/2018 04:29 pm
95 2.3l short block
Date: 03/18/2017 04:54 pm
Date: 11/08/2019 10:01 am
Date: 05/24/2020 08:19 am
73 Runabout
Date: 11/20/2017 03:19 pm
Seeking 1971-1973 Rotors
Date: 04/08/2021 12:23 pm
Offenhauser 6114 dp
Date: 09/12/2017 10:26 pm
  • Online today: 267
  • Guests: 250
  • Total: 250
1980 Ford Pinto carburetor PLEASE HELP!!!
Started by drive80pinto, October 12, 2009, 09:18:09 PM
I can safely tell you, yes you can swap out the coolant controlled choke with the electric choke. I did exactly that on my 77.
kevin.s 80
i drive an 80 coupe and am using an aftermarket weber carb but i have a manual choke which is controlled by a small lever sort of by the dash with a cable going straight to the carb im not sure if its stock but it looks like it but its really simple and if you can get your hands on one i would recommend
dont sweat the petty stuff
drive80pinto
Hey everybody,
I bought my pinto a few years ago and it didn't run. i rebuild the motor and had it going but it has always run bad. i figured i would get a new carb so i bought one that is the same one on my car. however i just found out that the carb on the car was for the wrong year it is for up to 1976 models i think because it has coolant regulated choke. i think i need electronically controlled choke. i think i can just switch out the coolant style choke with the electric type.
Does anyone have feed back or where i could just by the right choke assembly for my 1980 pinto??
Help would be great thanks
