Date: 01/23/2023 02:22 pm
Pinto Watch
Date: 06/22/2019 07:12 pm
NOS Sedan decklid
Date: 10/23/2019 11:51 am
parts needed
Date: 02/20/2017 07:58 am
Rare parts for sale
Date: 09/10/2018 08:38 am
Date: 02/05/2020 11:06 am
99' 2.5l lima cylinder head
Date: 01/13/2017 01:56 am
1972 Pinto SCCA BS race car
Date: 10/23/2018 04:01 pm
Crankshaft Pulley
Date: 10/01/2018 05:00 pm
  • Online today: 502
  • Guests: 394
  • Total: 394
will a 350 holley 2 bbl fit a stock 2.3l intake?
Started by flyboy1, October 05, 2009, 11:02:39 AM
PintoMan1
in order to change from a 2-barrel to a 4-barrel wouldn't you have to change the cam to make it work? correct me if i'm wrong.
1973 pinto runabout
moonman
i have a 9776 or 1465 not sure wich  number applys, the only problems i've had is a stumble off idle.
streets the game, sneaks the game love to go fast in Little cars.
CRUISEWAGON77
Is the "EFI" lower intake a good base for a lightly modified 2.3?  I would like to ditch the stock carburetor (dad has been having problems for years) and upgrade to a 2 or 4 barrel.  Thoughts?
Bought brand new by my Dad, 36yr OLD STOCK WAGON.  CAME AS YOU SEE IT, soon to have some bolt on goodies.
72pair
The list #8007 is actually intended for small v-8, 6cyl, and 2x4 setups. It tends to run a bit rich for a 4cyl. I guess you could try the power valve restrictors and crutch the mid and high range with squirts and jetting. A good carb shop could rework the fuel curve but probably $$. I tried one several years back on an offy dualport...IIRC seemed to run best with the power valve plugged. Jetting was hit or miss...everyday was something different so I switched to an efi base with a 350. Would like to hear other experiences as there's always someone who claims to have "made it work". JT ::)
What about the # 8007 Holley 390 cfm made for 4/6 cylinder engines?  Their all over E-bay.  Thanks again.
72pair
I'd stick with the 350 two barrel. Add a set of racer walsh power valve restrictors if needed. The correct 390 four barrel(list #6299) is hard to find. I have both in use on cars now, both work well, but day to day I feel the 350 is the most consistent thru all rpms. JT
Which carb, 350 or 390 gave the best streetable hp and driveable torque? Which one would you use for a hot street Pinto? Thanks.
Thanks! I've got both. The triangle one should work better because the 9" one will have a sharp right angle turn to enter the carb. Just glad to hear it clears.
72pair
I used either a 9" round chrome housing with a 2" tall element or the old weiand triangle foam air cleaner. Either one went under the stock hood on my '72 2.0 converted to 2.3. At some point, I trimmed the collar height down on the chrome base because I'm still using it on my 2.0 with spearco intake and 390 holley. JT
Quote from: 72pair on October 05, 2009, 03:35:58 PM
I ran mine with long studs and a 1" spacer plate. I felt I could seal the plate to the intake better. The 350cfm carb seemed to like a 2 hole spacer IIRC. My $.02. JT
What did you use for a air cleaner? Did it clear the stock hood with out a scoop?
72pair
Take off the ERG plate and it will bolt right on.
flyboy1
im looking for a 350cfm Holley for my pinto.....but wasn't sure if the Holley 7448 carb would bolt right on of if i need some kind of adapter?
