Date: 07/04/2017 03:26 pm
Wanted hood hinges
Date: 02/17/2020 05:30 pm
1974 Pinto Door Handles
Date: 03/07/2017 04:06 pm
Date: 11/11/2019 04:49 pm
Date: 04/12/2017 08:15 am
Date: 03/06/2019 06:40 pm
74 4 spd and rear axle
Date: 09/26/2018 03:51 pm
Date: 10/03/2018 02:00 pm
looking for parts
Date: 06/19/2020 02:32 pm
  • Online today: 577
Pedal assembly interchange
Started by svoman2300, November 01, 2004, 12:07:34 AM
I think they are all the same.  The clutch pivot pin broke on my 79 wagon and I used an assembly out of a 74 or 75 with no problems.  The parts looked identical to my original ones.  Keep in mind, you do not need to pull the pedal frame from the car.  I am pretty sure you can swap the brake pedal without removing the frame.  The clutch pedal assembly bolts onto the side of the frame.  All the holes should be already stamped into the frame.  The Mustang II pedals are different from the Pinto's.
svoman2300
I searched and didn't find anything. I am going to do a T5 swap in a 79 auto. wagon. What years peadal assemblies can I use? Just 79 and 80 or will an asembly from an earlier model work?
Thanks
Rick
84 Mustang SVO
81 AMC Eagle
