1980 Ford Pinto For Sale
Date: 07/01/2018 03:21 pm
'78 Pinto Windshield Trim
Date: 05/09/2017 10:46 am
Hatch needed
Date: 09/10/2017 09:16 pm
Date: 09/15/2019 08:30 pm
Pinto 4-spd transmissions
Date: 06/15/2018 09:15 am
2.3 bellhousing stick
Date: 07/24/2019 06:50 pm
Date: 09/01/2017 07:52 am
Date: 04/13/2017 04:56 am
Date: 10/10/2019 09:42 pm
  • Online today: 403
  • Guests: 161
  • Total: 161
PANEL REMOVAL ON 77 CRUISIN WAGON!
Started by GERBEAR, October 31, 2004, 07:32:04 PM
First I would remove the carpet along the sides.  Then you will need to remove the moldings that cover the screws.  One is at the rear, next to the hatch and the other is next to the door.  On my car, the ones at the rear are body color and the ones on the sides are grey or silver.  They are both held on by adhesive, so they should be easy to pull off.  Once you remove the moldings you will see the screws.  If I remember there are 6 or 7 screws.  Then you will have to take a putty knife or something to cut thru the calking they used to seal the sides.  That is the most difficult part of the whole thing.  It will help if you have someone on the inside helping to push.
GERBEAR
I just bought a 77 cruisin wagon I need to take the panels off to do some body work, plus I need a wiring harness!
