1975 Ford Pinto
Date: 01/13/2020 11:02 am
Front sway bar frame brackets
Date: 07/13/2017 01:05 am
Date: 08/02/2019 04:18 pm
Bumpers
Date: 07/06/2018 04:47 pm
Drip rail chrome
Date: 01/14/2017 09:18 am
Date: 01/28/2017 12:30 pm
SOME PARTS FOR SALE
Date: 01/11/2017 10:45 am
74 hood
Date: 07/03/2017 03:46 pm
Date: 07/08/2017 08:25 pm
  • Online today: 394
  • Guests: 385
  • Total: 385
Holley 500 on a 2.0 pinto
Started by Lilljebjorn, August 10, 2009, 03:27:41 PM
Lilljebjorn
Quote from: oldkayaker on August 11, 2009, 05:45:49 AM
I tried a 500cfm Holley 2bl on my 71 2.0 a long time ago.  It was a bit much for the street, it would bog when mashing the throttle.  I maxed out the accelerator pump to no benifit.  The only way I found to make it driveable was to enrich the main jets excessively.  This killed mpg and it did not feel noticeably better than the stock carb.  I went back to the stock carb.  I see Racer Walsh now sells a restrictor kit for this carb that is advertised to fix this problem: http://racerwalsh.zoovy.com/product/RWA1218/carb_restrictor.html
My engine spec was: big valves, home porting, mid cam, headers, and about 8:1 compression.
Thanks m8!
This was helpful, think my engine is a lot wilder in spec than yours,
so I will go for the 500 carb. Mpg is not an issue on this car as
it will only see a little road use and mostly trackdays etc.
Still thankfull for more coments and experience about this...
Lilljebjorn
The engine spec is;
92mm bore, longer rods(saab), forged pistons, big valve ported head, Newman cams phase 4.5 cam,
comp ratio 12:1
I ran a Holley 350 on a modified 2.0 and it ran great. I agree, a 500 is way too much for a street driven car. Actually, when I first put the 350 on all I had was a header and an adjustable cam pulley, but it ran good and was a huge improvement over the 5200.
I would think that a 300cfm carb would Be the Ideal size for a street car. Nice flow. Not too much and not too little. I hope you can return that carb. I would and i would get the holley 300-340cfm carb.
72pair
First, how modified is your engine? From past experience, a 500 holley just would not be my choice for a street engine. The out of the box calibration is way too rich for a 2000cc. The 350 or even the 390 4 barrel provide much better response. The local dirt guys run 500s, but they either idle or run 8000 rpm. I'm sure you'll receive several more opinions here, but I'd like more engine/application info. JT
Lilljebjorn
Hi,
I have just bought myself a holley 500 2bbl carb for my 2.0 engine.
Doing my tuning the David Vizard way...
Can anyone help me with what powervalve I shall get and what about jetting?
Thankfull for any help from someone with experience of this.
Johan
