Date: 05/18/2020 10:22 pm
Rear Bumper
Date: 07/26/2021 01:08 pm
72 Pinto
Date: 03/07/2019 12:07 pm
Date: 10/31/2018 12:00 pm
2.0 Cyl Head1973
Date: 11/29/2018 12:51 pm
1980 Pinto Wagon
Date: 02/29/2020 07:01 pm
Early Rare Small window hatch
Date: 08/16/2017 08:26 am
Pangra wanted
Date: 02/05/2017 01:58 pm
Date: 05/22/2018 01:54 pm
  • Online today: 529
  • Guests: 240
  • Total: 240
1980 pinto with ranger roller cam swap questions
Started by flyboy1, August 07, 2009, 06:00:51 PM
89 to 93 stangs and 89 to 92 rangers. you can use the cams later than 93 but need the earlier roller followers because of the stem issue. the cam would be the same early or late.
The first roller cam setup I got was from a 93 and it would not work, as it did have the 7mm valves. An older year would more than likely work. Not tto sure what years it is though.
turbo74pinto
the 93 should be the right one.  the later rollers and 2.5s ran a 7mm valve stem and the followers wont work with your valves, but the cam will.  i think the 7mm valves started in 95???
bob
The only big difference is the width of the groove where the rocker arm slides over the valve stem. MUST match each other. I think the early arms are cast and the late one forged, but I may have that backwards.
pintoman
Yes they will.I have been running a Ranger Came for about 6 years.
flyboy1
will a 1993 ranger roller cam and roller followers swap strate in to a 1980 ford pinto 2.3l head????????if a 93 wont what year ranger cam will swap in to a stock pinto????
so if i buy a cam and followers out of a 93 ford ranger thay will fit right in with the stock springs and valve stems........
