1977 Pinto for parts
Date: 10/10/2018 06:25 pm
Date: 11/05/2020 06:32 pm
Date: 05/24/2020 08:19 am
Date: 07/01/2019 12:23 pm
1977 Pinto Hatchback Parts
Date: 08/29/2020 05:31 pm
Date: 02/18/2017 05:52 pm
Anyone scrapping a 1980
Date: 03/13/2020 08:46 pm
SVO SWAP
Date: 03/15/2018 03:12 am
74 & Up Parts
Date: 01/20/2021 03:22 pm
  • Online today: 2,670
  • Guests: 558
  • Total: 558
Need sunroof weatherstripping for '80
Started by Scottdr6, October 13, 2004, 08:46:18 AM
totljeep
If you have or know someone that has an air compressor, try using a spray nossle to blow out the weep holes to the sun roof. As for the weather seal, you might try a good cleaning then use a liberal amount of vaseline on it to try for a better seal until you can find a replacement. Just a thought.
FIX MY PINTO ELSE I'LL DRIVE IT LIKE IT IS!
Good luck... I'm still trying to find a factory sunroof to replace the broken glass on my 78 Pinto. If you know of any sunroofs lying around let me know....
Now that I think of it, you may want to check www.jcwhitney.com
They do have replacement weatherstripping, so they might have the type you need.. As for the drain holes, what you might be able to do is run a coat hanger throught the drain holes to clear them out.
A friend of mine did that on his 88 Ford EXP, and it helped.
Good Luck
Scottdr6
I have a 1980 Pinto that needs new weatherstripping for the factory sunroof. Anybody know a source? Also, how do you go about cleaning out the drain holes? Thanks!
