Date: 07/03/2025 04:35 pm
1974 Ford Pinto Squire Wagon
Date: 05/30/2020 01:51 pm
1979 pinto
Date: 04/19/2018 02:02 am
Pinto drive train
Date: 06/29/2018 08:32 am
74 Pinto wagon armrests
Date: 01/18/2017 07:04 pm
Mallory Unilight dist 2.0
Date: 10/25/2019 03:44 pm
Date: 10/03/2018 02:00 pm
Date: 12/09/2016 08:34 am
Date: 10/10/2019 09:42 pm
  • Online today: 450
  • Guests: 402
  • Total: 402
FORD PINTO C4 AUTO
Started by lefty, July 17, 2009, 10:14:07 PM
Well being poor at this point is an advantage because I can't buy it untill spring when i get my tax check.  So i will have heard about any issue they might have.  Hopefully they are small or non-existant.
turbo74pinto
ahhh...my cars so freaking solid i dont want to cut it up unless i absolutely have to.  im in the same boat as you with the d5 or sfi.
bob
I have a friend of mine that has a C4 in his pinto and uses the D5 bellhousing.  It wouldn't surprise me if we had to do some "adjustments" here and there.  However the people who are supposed to be making the new bellhousing know to keep it as tight as possible.  I understand that there is some clearancing to be done with a adapter plate regardless of who's you use.  If the new bellhousing wasn't coming out I would either try to find a D5 bellhousing [rare and exspensive and old] or go to the adapter.  Since mine is not a restoration the mods don't bother me.
turbo74pinto
jim, i wondered about that addaptor in a pinto.  i know the c4-302 bell out of a mustang 2 wont fit without some mods, unless the motor is moved forward.  if i remember right, i had an issue with the top bell bolts not clearing the firewall.  i wonder if a fox body bell would fit in a pinto???  kinda doubt it...but ive never checked.
bob
Bob,
That is the one.  i like my feet too so i will get one.  if it takes a little time no problem for me as I have to wait on my income tax refund check.  :lol:
there is another company making an adapter plate that I like better than stingers.  Nothing wrong with stingers I just like the other better.  I am at work so i don't have the name.  the name canfield comes to mind but probably not right.
turbo74pinto
Quote from: dick1172762 on August 11, 2009, 12:08:57 AM
You can use a Pinto bell houseing / converter with a C5. Direct bolt on.
the only way this would work is if you have a c4 tranny to start with in your car.  c3s run a different tranny bolt pattern to the bell than the c4/c5s.
ive been told that the c5 runs a deeper bell for a thicker converter.  if that is true, id ASSuME that the the tranny mount would be back a little farther with a c5 bell.
bob
ps.  jim, i emailed joe about those sfi bells a few days back.  i guess they are still a little ways out.  if this is the one your talking about, its a bell to run a 2.3 to a c4.  stinger sells the addaptors to run a v8 bell pattern to a 2.3.  i like my feet....i plan on getting one when they become available!!
Just a note for you turbo or higher horsepower cars, this fall there is supposed to be a bellhousing coming out that will bolt up a V8 C4 directly to a 2.3.  BTW: It will also be SFI approved so it would be good for safety.  As the last of the D5 bellhousing disappear these are going to be a good alternative.  Also the D5 bellhousing is 35 years old and becoming very pricy.
Just an FYI
turbo74pinto
the tranny will fit the engine.  i dont know how big the c5 convertor is and if it will fit the pinto tranny tunnel. best thing to do is take a look and a few messurments, and see if it will tuck under there.
bob
lefty
Quote from: turbo74pinto on July 18, 2009, 01:29:42 PM
yes, years had different splines on the clutch hub and converter and differences in valve bodies.  i know 70 was a one year thing.  i think there were 2 version between 64 and 69.  then the last was 71-79.  all up to 70 were 24/24 spline, 70 was 26/26 and later were 26/24.  rangers didnt come with a c4 but they did come with a c5 which is pretty much a c4 with lock up.  i guess c4 parts could be put into a c5...valve body, bell housing and converter.  i guess the c5 had a better oiling system.  lotsa info on the web.  im looking up the same thing since im thinking of going the c4 route.
any 2.3 tranny will fit your 2.3.  you just have to use the correct flex plate and converter.  the question is, will the tranny clear your tunnel/firewall.  i dont know how big the bells are on some of the autos and i dont know how much clearance youd have with a big converter.
bob
So, If I use say a 1984 Ford ranger 2.3  tranny and use the flex plate and torque converter that came with that tranny it shoudl work on my 77 2.3 engine as long as splines match-is that right???
turbo74pinto
bob
depends on the year i think. its its Pre 85 and a 2.3 Ranger auto it should work. ( we replaced my moms old c3 witha c4 from a 2.3 Ranger believe the year was 1984. Hope this helps.
lefty
Is there any difference between Ford Pinto C4 and other Ford C4's if so what. Also will a Ford Pinto 77 2.3 marry up to a Ford Ranger automatic trans??
tks
