turbo 4 cyl and aod trans
Date: 12/14/2019 04:55 pm
Pangra wanted
Date: 02/05/2017 01:58 pm
Date: 01/28/2017 12:30 pm
1980 Pinto Wagon
Date: 02/29/2020 07:01 pm
1977 pinto rear bumper
Date: 04/19/2021 11:57 am
Date: 02/10/2017 09:30 am
Wanted hood hinges
Date: 02/17/2020 05:30 pm
v8 springs
Date: 05/07/2017 04:46 pm
71 72 front bumper brackets
Date: 06/10/2020 10:55 am
  • Online today: 288
  • Guests: 256
  • Total: 256
what is the duration on a stock 1980 camshaft?
Started by flyboy1, July 17, 2009, 09:25:46 PM
correct, when you get up to about 450 lift you need to look at clearance on the guide bosses and coil bind.
Not 100% sure but somewhere around 272 (actual not @ .050) and the stock lift is .399. When you start getting to .290 and above the idle gets choppy but there are a lot of other things involved in picking a cam.
flyboy1
i was told if the duration on a pro cam is to far off of the stock cam that it wont idle and i cant find out what the stock duration is to know what duration is to much.......
