Pinto for sale
Date: 04/19/2017 10:15 am
Date: 07/08/2022 11:51 pm
WTB Cruising Wagon
Date: 12/07/2016 05:35 pm
1976 Squire wagon
Date: 09/12/2018 10:30 pm
Automatic transmission
Date: 02/13/2021 02:52 pm
1980 Pinto for sale
Date: 11/24/2016 06:32 pm
Wanted 71-73 Pinto grill
Date: 03/09/2019 10:45 pm
Date: 09/15/2019 12:38 pm
Date: 03/16/2017 10:00 pm
  • Online today: 583
  • Guests: 509
  • Total: 509
Valve lash
Started by delizious, July 15, 2009, 05:26:04 PM
delizious
OH! i knew that...my car is a '73
Lost 1972 Ford Pinto
Gained 1978 Ford Pinto
The simplest method is to rotate the engine until the lobe is up and then check that valve's clearance (between the lobe and the follower rocker).  For the stock cam, the cold clearances are 0.008" intake and 0.010" exhaust.
I have not tried it but that table will save some effort by minimizing the engine rotations.  Per the 1974 Ford manual, number the cam lobes 1 thru 8 front to back.  Rotate the engine until the number 1 lobe is down (valve compressed) then set the #6 clearance at 0.008" (intake) and the #7 clearance at 0.010" (exhaust).  Continue down the table until all valves are adjusted.
delizious
Ok, I'm a little stuck here on this one i have a Chiltons manual american cars from 1966 to 1973 book thats REALLY REALLY OLD and i treat it as if its my bible which it is :D but its not very specific. it says under valve clearance adjustment 2000cc engine-set cold: Valves to adjust to depressed
             .008    .010
   No.1     No.6     No.7
   No.2     No.8     No.3
   No.3     No.2     No.5
   No.5     No.4     No.1
So im a bit confused from this diagram it shows, can someone elaborate further?
Thanks!
