1977 Left Side quarter panel
Date: 06/10/2019 04:16 pm
1971 2 lt Cam
Date: 10/10/2020 06:27 pm
Mirror
Date: 04/15/2020 01:42 pm
72 Runabout Sprint Edition
Date: 04/25/2018 02:51 pm
Date: 07/01/2019 03:17 pm
Date: 11/23/2017 05:44 pm
NOS Sedan decklid
Date: 10/23/2019 11:51 am
Date: 09/05/2018 06:30 pm
Looking for front seats
Date: 08/10/2021 09:54 pm
  • Online today: 1,166
  • Guests: 476
  • Total: 476
Cure for windshield wipers ?
Started by tdoorly, October 11, 2004, 07:00:58 PM
OK It's not an "easy" fix, but I'll give it a shot. If you've got a haynes manual , it describes how to pull the pivot shafts & linkage. once you've got the linkage in hand check the bushings. I'd asssume they're nylon. If that's the case I'm not sure where you'd get spares from. If on the other hand they're bronze(or brass) you can get them from your local home improvement store. They may even have a very few nylon bushings. those bushings SHOULD push out rather easily. Or they may just disintegrate in your hands, so measure them BEFORE you pull them out. get some bushings that fit the shafts, if they don't fit the linkage you can always file them down in a drill/vice lathe. (put your drill in a vice, lock the bushings down on a scew with a nut, chuck the screw into the drill, turn it on & file away) This will take the slack out of the system.
My '74 AND the '80 I had both have the same symptoms, & I can't recall my wipers ever stopping.
tdoorly
Does anyone know of a cure or fix for noisey and jerky windshield wiper linkage problem that all 3 of my Pintos have?  It doesn't look like they are easy to get to.   Help -  before  they stop working.
Tom D.
