Date: 05/19/2018 04:56 pm
Date: 07/20/2018 03:00 pm
Alloy Harmonic Balancer
Date: 07/10/2020 12:17 pm
Date: 06/24/2020 06:12 am
1978 fuel sendng unit
Date: 05/27/2020 09:54 am
cam pulley
Date: 05/30/2018 04:56 pm
1971-74 Various Pinto Parts
Date: 01/18/2020 03:44 pm
1976 pinto for sale
Date: 01/12/2017 02:08 pm
78 windshield trim
Date: 02/01/2020 08:46 am
  • Online today: 553
  • Guests: 466
  • Total: 466
Would a stock 76 2.3 be zero deck?
Started by Pale Roader, July 04, 2009, 09:05:36 AM
Pale Roader
Quote from: oldkayaker on July 05, 2009, 06:24:38 AM
Based on stock target dimensions (stroke=3.126", rod length=5.205", block deck height=8.368", piston height=1.583"), the piston should be down in the block about 0.017".  I do not remember where I got the stock target dimensions.  Also manufacturing tolerances will move these numbers.  A 33 year old engine probably has had some work, so you need to measure your deck height to get the actual number.
According to the Ford 1976 manual, your head has a volume of 63.7 to 66.7cc if it is stock.  This Racer Walsh publication has information on different heads: http://static.zoovy.com/merchant/racerwalsh/Back_2_Basics_Sheet.doc  Besides this forum, there are several other forums that cover the 2.3 since it was used in the Mustang, Thunderbird, Ranger, Mekur, etc.  As always there are exceptions and errors in these publications but they are as close as I have found.  Another useful 2.3 engine info link:
http://www.esslingeracing.com/faq.htm
Hey thanks. Sounds like this thing is already very close. If it IS .017" then i'm a thin gasket and a closed chamber head away from quench without a rebuild. Quench is a BIG step towards a more efficient engine. I'll have to research deeper into this. I'm just really strapped for time right now so i thought i'd ask a few quick questions. And as far as i can tell, my 2.3 has never been apart. Pretty solid little car all around actually, aside from the obvious NW rust issues.
Pale Roader
I should also ask, if it is not zero deck, how far are the pistons down in the hole?
Pale Roader
No one locally can answer me this, they just throw these engines away. Would my 76 2.3 have a zero deck? or is the piston gonna be down in the hole?
Also, is my head a closed chamber? If not, then is there a single plug closed chamber head for the 2.3?
I admit i know nothing about these things. I know Mopars and some GM, but this is the first Ford i've ever owned and till now i dont think i've even opened the hood more than once.
