72 Pinto parts
Date: 11/14/2019 10:46 pm
Date: 05/15/2022 11:36 am
Date: 01/19/2021 03:56 pm
Date: 01/24/2021 07:54 pm
Date: 03/06/2017 01:19 am
Date: 08/24/2018 02:50 pm
Hoard of Pinto parts
Date: 12/17/2016 04:14 pm
Date: 08/01/2018 01:27 pm
Date: 06/22/2017 07:19 am
  • Online today: 452
  • Guests: 248
  • Total: 248
Ford 8 Inch question
Started by Pangra74, July 01, 2009, 09:32:48 PM
 ??? So did I just get lucky or what? ??? My 8" came from a '68 Mustang. Bolted in, no mods. I took spring perches and u bolts as well, they are different as 71HRP stated. I traded the 5 lug axles and drums for a complete 8" with 4 lugs that the guy said came from a 6 cyl Maverick. No idea what year. Slid the axles in, drums on, Pinto 13" wheels on and away I went. Now I read on here (and different posts about 8" swaps) that there are bunches of different 8" configurations!  :surprised:
71hotrodpinto
Quote from: skunky56 on July 03, 2009, 02:09:20 PM
Joe, your better off finding a 8" from a V6/ Pinto/Bobcat or V6-V8 Mustang 2, it is a bolt in with no mods, make sure you get the U-bolts and lower shock mounts with the 8".
Yes do that, Harder to find but waaaay less work. If you have an earlier pinto then dont get excited and grab the later model leaf springs also. They are longer and have a different axle mounting position farther back. Makes the wheels sit "weird" in the back. I tried that and that was a bunch of work that i had to undo to go back to stock 71 leaves. You can however stiffen up eariler leaf springs by grabbing a couple of leaves out of the later springs and then adding them to the earlier springs.
But YOU MUST grab the leaf mounting "plates" that locate the axle on the leaves. The locating pad has an oval hole in it to mate to the oval plate locator . The early ones are round.
Sorry just ran away with the subject at hand into a different place LOL! I do that.
B303,1.7 Rockers,beehives
'68 port/polish heads
Coated Must II headers
Edelbrock Airgap
Holley570,Msd dist,CraneHI6
Mil
skunky56
77 Starsky/Hutch 2.3 Turbo A4OD Sunroof
78 Wagon V6 C3
I just want to add that the drums from the 6-3/4" Pinto rear will not fit the (Pinto/Mustang II) 8" rear, even if they have the correct bolt pattern. The center holes are different sizes. Ask me how I know?
Tom
The early ones were 4.5" four lugs. Either the later ones or the V8 ones had five lugs.
I ended up having those 4.5" flanges re-drilled as 4.25" on my Maverick swap axle.
I'm 99.7% sure Mavs were 4 1/2" 4 lugs.
Are you sure CB? My 8" came from a '68 mustang but the 4 lug axles came from a Maverick and my Pinto wheels bolted right up. I never knew there were so many different 8" set-ups...
And no, the 6-3/4 stuff won't work.
FYI, The pinto is a 4lug 4 1/4" pattern. Same as Mustang 4 lug, also Fairmont and some birds. The Maverick was a 4 lug 4 1/2" pattern.
My experience going from a 6-3/4" Pinto to "small bearing" 8" Maverick axle, the plates don't swap.
Pangra74
Do any of you guys know if the stock drum backing plates from a stock 6 3/4 rear will bolt to an 8 inch rear from a Maverick? I'm looking at an 8" housing on ebay. Would also like to get 4 lug axles if possible.
Joe
1974 Orange Runabout
