1971 Pinto Parting out
Date: 07/06/2018 01:11 pm
1973 Interior parts wanted
Date: 01/02/2017 11:02 pm
72 Pinto parts
Date: 11/14/2019 10:46 pm
Date: 01/23/2017 07:41 am
78 pinto wagon
Date: 06/04/2020 12:42 pm
Lower Alternator bracket
Date: 08/26/2017 05:11 pm
Esslinger 2.0 intake
Date: 03/06/2017 11:58 am
Date: 09/06/2020 01:57 am
Date: 09/15/2019 12:38 pm
  • Online today: 295
  • Guests: 168
  • Total: 168
Desktop Dyno files
Started by crazyhorse, October 09, 2004, 01:46:38 AM
Thanks Brad, I'd been doing that. I was able to finnesse the cam profiles to get 135HP@ 5500rpm and 152ft-lbs@ 3500rpm Pretty respectable for a 390cfm 4BBL & hipo manifold & mufflers. THese are REAL close to the numbers I want to make in my car. I'm thinking 135HP  is a pretty good step up from 88HP which it's got  now (assuming the engine is as stock as it looks)
 Use a 1.74 Int valve size, 1.50 ex valve size and I figure with about .400 lift you will get 141 cfm on the intake side and 112 cfm on the Ex side. Use the low proformance head. I think this will get you real close to a stock set up.
Where can I get EXACTING specs on the stock 2300 head for use on desktop dyno?
Brad? you got these? anyone??????
