Great Cruise wagon
Date: 12/17/2016 03:39 pm
Date: 09/02/2021 08:21 am
77 Caliper Bolt
Date: 08/21/2018 04:02 pm
Date: 02/14/2018 01:34 am
74 hood
Date: 07/03/2017 03:46 pm
Date: 10/25/2019 03:30 pm
Pinto Parts for sale
Date: 06/19/2017 02:01 pm
Weber dcoe intake 2.0
Date: 08/01/2018 01:09 pm
Many Parts Listed Below
Date: 04/20/2018 11:15 am
  • Online today: 583
  • Guests: 472
  • Total: 472
Rear shocks for wagon
Started by 289pinto, June 14, 2009, 04:43:10 PM
wedge446
I use rear shocks for a 77 chevy nova on my 75 wagon with no ill effects.
Mike Modified
Monroe's eCatalog www.monroe.com shows that they still make the "SENSA-TRAC® PASSENGER CAR SHOCK ABSORBERS" #5771 for 78 (75-80) Pinto wagons.
flash041
I got mine at oriley's last year.took a couple of days to get them in.The boxes were a bit beat up and had a thick layer of dust on them !!But the shocks were new and shiney.
there are diff part numbers on the rear wagon shocks but there is one with the same numbers here is the link to it http://shop.oreillyauto.com/ProductDetail.aspx?MfrCode=MON&MfrPartNumber=5819&PartType=50&PTSet=A
Hope this helps dave
Thanks for your contribution Tom! I have a good set of rear shocks from my 78 that I hope to use on my 73 wagon. Think it will work?
glad to help. anyway i can or know how too lol. =) good luck on your car, its very nice. wish i could have the time and money to put into mine right now.
289pinto
Thanks for all the help guys. I called my local napa when I was at work and he ordered me some. Should be in thursday, not in a big hurry so it will work out fine. Thanks!
1978 Pinto wagon, 289, 8" rear, 17" cobra R rims
Checker Shucks/cragen or also known as O'rielly's Now. they carry the rear wagon shocks. This is where i purchased mine,
http://shop.oreillyauto.com/productdetail.aspx?MfrCode=MON&MfrPartNumber=5771&PartType=50&PTSet=A I do hope this helps. its a direct link to the Website with the Shocks for you .
It has been about 10 years since I purchased the KYB gas shocks on my 79 wagon but I remember just going down to the local auto parts store that carried KYB's and ordered them.  I hope they have not discontinued them......
The Wagon shocks have a bit more travel.  While I qualify this with "do at your own risk" I have used the sedan shocks on my '73 wagon.
There is about 1-1/2" more travel in the wagon shock. You can compensate for about an inch of that just maximizing the threaded portion of the shock.  I used three of the bushing washers between upper end of the shock and its corrosponding lower bushing.  I then used a tubular spacer of about 5/8"-3/4" on the lower end of the shock and its upper bushing washer.
This effectively made the shock about 1" longer.  I have not had issues missing the 1/2" of length. Nor have they bottomed out on me due to limited travel.  There are also extenders you can purchase.  Just don't put too much "extention" on the top of the shock or it can bottom out.  Unless your one to fly over rail road crossings, over extending likely would be less of an issue.
Anyway, for me it saved the hassle of finding and paying for the stock dimension shock.
Tom
I got mine (for my wagon) at O'Reilly's - though I don't know if you have access to an O'Reilly's. You can also try Rock Auto (www.rockauto.com). Let me know, I can always pick up a set for you and have them shipped.
289pinto
Where do you guys get your rear shocks for a wagon? I checked autozone today and they are discontinued! I can check some other parts stores just wondered if anyone new off hand? Thanks
