Date: 09/21/2018 11:35 am
Date: 02/18/2017 05:55 pm
Date: 02/28/2018 09:37 am
Date: 08/01/2018 01:27 pm
Need 2.3 timing cover
Date: 08/10/2018 11:41 am
1974 Ford Pinto Squire Wagon
Date: 05/30/2020 01:51 pm
Date: 06/24/2020 06:12 am
Pinto drive train
Date: 06/29/2018 08:32 am
  • Online today: 553
  • Guests: 233
  • Total: 233
Vacuum advance clearance
Started by bowser22, June 13, 2009, 01:06:03 PM
Looks a little like an older MG?
bowser22
I installed it into a Grand Dutchess Migi kit car.
what car did you put it in?? did you put it in as a front drive?
You could pull the distriburor prt way out and turn, resecure and move the wires around to gain diapham clearance. Then retime it, you know, TDC#1, rotor position.
bowser22
Hi! Im new to the forums. My issue is that i dropped a new pinto engine off a 78 into my little kit car because the old engine had erratic timing and was just a pain in the butt. Now with this new engine the distributor vacuum advance rubs against the steering column and makes the wheel very stiff and hard to turn. To remedy the situation i made some shims up at my shop to raise the engine and the clearance is still poor. Any ideas? Also one of the mounts didnt survive the frequent reinstallation of the engine, are all the mounts the same the whole way through?
