1971 Pinto Parting out
Date: 07/06/2018 01:11 pm
sport steering wheeel
Date: 10/01/2020 10:58 pm
Date: 10/14/2019 08:24 pm
Date: 03/25/2019 09:02 pm
Pinto Vinyl Top
Date: 10/09/2020 10:29 pm
Date: 10/27/2018 03:30 pm
Front sump oil pan
Date: 01/02/2017 06:54 pm
Early Rare Small window hatch
Date: 08/16/2017 08:26 am
74 Wagon Interior
Date: 01/22/2017 06:38 pm
  • Online today: 295
  • Guests: 237
  • Total: 237
Dashboard?
Started by beicholz, June 10, 2009, 09:05:35 AM
Went to the a place called "Urethane supply company" and got some flexible bondo-type filler. I also used some of that "in a can" spray insulation foam to fill the deep cracks. Was a lot like bodywork. Then, I covered the whole thing in a textured finish (from auto paint supply store), and painted it with a special vinyl/plastic "dye". Lots of work.
pintoguy77
Hey popbumper,what exactly did you use to repair your dash cap?i like friggin with that stuff.
That was a picture of my restored cap, CB - it was tan in color.
Who was it on here that was thinking about doing our recovers, about a month ago??? I seen some pictures and they looked like new.
Be careful about applying new vinyl; if you add any thickness at all to the pad (with foam) before you wrap in vinyl, be sure to NOT add it to the ends, or the pad becomes too wide to fit. I know, because I had one redone this way. Just an FYI, good luck!
infl858
Yes , I agree, In the time I have spent looking for dash pads,, all I discovered were cracked old ones,,, and new plastic covers,, I am thinking of covering it with heat applied vynl in its original color. Victor
Good luck on your search, hope this one works out for you!
99% of the original dash pads out there are cracked, and new ones are near non-existant, and very expensive IF you can find them.
You can find plastic caps on EBAY or at JC Whitney (they pop over the dash and cover the problem), or you can try and repair it.
The repair process is quite lengthy and involved, though it can be done (I restored my own dash cap, it was a lot of work).
Best wishes on your possible car buy!
If you mean dash pad E-Bay or JC Whitney. If it is the metal dash best place would be me.  Fred   :)
beicholz
A 1974 pinto I'm considering purchasing has a cracked dash.   What's the best place to get one?
Hoping to be a proud Pinto owner soon!
1973 Pinto Squire, 59K Miles, 2.0, Auto P/B, A/C
1972 VW Karmann Ghia Convert. (Red/Black), 2K Miles on restoration, One Owner
1972 Chevy Vega (virtual owner - in the junkyard)
2011 Subaru Outback 4WD
1 Yam. Golf Cart: Our "car" on Catalina Island
