Date: 09/12/2018 04:07 pm
1979 Pinto Rear Bumper
Date: 03/26/2021 03:26 pm
71-73 Front Kick Panels
Date: 04/25/2021 07:24 pm
72 Pinto
Date: 03/07/2019 12:07 pm
1974 Wiring diagram free
Date: 10/27/2019 06:56 pm
Date: 08/24/2018 02:50 pm
Date: 02/14/2019 06:27 pm
Date: 08/05/2018 01:58 pm
Clutch pedal needed
Date: 01/11/2024 06:31 am
  • Online today: 515
  • Guests: 281
  • Total: 281
help on kickdown
Started by 80bobcat, June 04, 2009, 10:35:27 AM
80bobcat
the connection..meant to be the 1st on previous post..then my camera died..I`ll try to get the others
Look Officer..it`s a Pinto would YOU stop short?
80bobcat
the bottom connection and a L bracket fabbed to hold it to the throttle plate
80bobcat
Well I went ahead with the kickdown..using the cable as mentioned.. again I must say I don`t know if its really needed but everything works just a bit better.. shifts are  smoother and having the tranny kickdown on its own is real nice.. I`m thinking that the lever on the tranny controls the fluid through the passages..etc making for better drivability?
I had help..lots of it
first off..the end on the throttle didn`t match so we took it off and replaced it with one from another accelerator cable I had trashed but stashed.. then the lever itself had to be put in upsidedown.. so now the pin was on the wrong side.. but with a cut and weld and some elbow we managed to get it to clear the tranny tunnel..all was clear...now a bracket fabbed and bolted to the bell to hold the cable in place and after some finessing and such we were done.
My job was to keep the beer cold..
Thanks for everyones input..it was well worth the trouble to add this cable
80bobcat
Quote from: 71pintoracer on June 13, 2009, 05:49:44 PM
They didn't have c4's, they had AODE's. You should be able to fab up a bracket to hook up to your c4. It won't hurt anything to run w/o it, you will just have to manualy downshift from 3rd to 2nd when you nail it!!  ;D
Ahhhhhh...... the info I really needed...... I was led to believe that without that kickdown that damage would result to the tranny..but if all I gotta do is manually put into 2nd when I need the extra go...well...I can live with that!!......thanks 71pintoracer and all the rest    :)
i think the sc -bird had the c4 but it was a specialty order.. i think. ive never found an auto one.
80bobcat
Hi all... just an update and another Q... after some digging I got a part # for a kickdown cable for the `87 Tbird SC auto... E7SZ-7A187-A
Anybody know if they had a C4 tranny in those? or if that cable can be adapted to fit a C4 ? tia
VC
I'm guessing a cable or bellcrank. The cable may be easier to cobble from factory or aftermarket parts.
80bobcat
Hi all.. got the turbo in and running..but now I`m wondering how people have modded the kickdown on the c4? if I remember correctly the original rod worked in the north/south direction and the turbo intake works in the east/west...right now its not hooked up at all and seems to shift ok..but I know I`ll have to address this sooner or later(not a daily driver yet!) will any damage result by not using it?..the guy who rebuilt it said he beefed it up to handle 6 cylinder HP.. whatever that means..anyways any thoughts, ideas, and solutions are welcome.......tia
VC
