1980 Ford Pinto For Sale
Date: 07/01/2018 03:21 pm
Date: 07/08/2022 11:51 pm
Lower Alternator bracket
Date: 08/26/2017 05:11 pm
77 Cruising Wagon Front Seats
Date: 04/12/2017 12:37 pm
ford pinto door panels
Date: 03/20/2022 07:51 pm
Hood Hinge rubber boots
Date: 09/28/2018 05:49 pm
pinto wagon parts
Date: 12/19/2019 01:43 pm
Date: 02/14/2019 06:27 pm
Date: 09/10/2018 10:41 pm
  • Online today: 617
  • Guests: 581
  • Total: 581
T-9 swap
Started by pinto78oh, May 27, 2009, 07:24:49 PM
Hi Brian,
I wish I had better news on my T-9 trans progress. I had some life changes that put my Pinto project quickly on hold for longer than I thought. I didn't go with the original 2.0L engine so I had (and still have) a couple of battles you won't have. I went with a 1.6L from 1966 so I have some flywheel to starter issues and the pilot baring needs to be drilled/replaced as it is too narrow/small for the T-9 input shaft. All this is very fixable but became low on the life list. Things are back on track so I hope to start soon where I left off. I included a link below to my T-9 mods. You should have it a little more straight forward if still mating to a 2.0L. Good luck and keep us posted on your progress.
http://www.fordpinto.com/index.php/topic,10435.msg69024.html#msg69024
pintopimp
Hello
I dont believe we know each other.  I'm a fellow Pinto owner( I have 4 to be exact).  Did you sucsessfully attach a T-9 to your 2 litre?  What can you tell me?  I'm about ready to do it myself.  I was told I may need to shorten the drive shaft and address the trans mount which is obvious.  Was your conversion sucsessful?  Did you take the bell housing off your 4 speed Pinto trans and put it on the T-9?
Thanks,
Brian
1973 Yellow Wagon
1972 Brown Wagon
1972 Red Runabout
1979 Runabout
1972 White Wagon
1971 Red Runabout
1971 Sedan
1974 Runabout
1972 Blue Runabout
1972 Red Wagon
1973 Chesnut Squire
1973 Yellow Squire
1972 Yellow Squire
1972 Yellow Turbo Wagon
Known as "the flipper"
Co-Owner of B&B's Used Pintos ;)
I am putting one in a 71 and always assumed I would need to do fab work. It looks like mine just needs about a 3 inch reinforced extension off the existing mount. I was going to use a poly isolator under the trans mounting tang (don't solid bolt without give). Bottom line, you need to fabricate. A welding shop or a good muffler shop may be a start.
pinto78oh
I need help put the t-9 in my 80 pinto but the trany mount doesnt fit will i have to get a omunt from the merkur or make one help ???
