Date: 03/23/2018 09:23 pm
Date: 02/25/2017 08:45 pm
Clutch Cable Needed
Date: 04/03/2017 10:54 pm
Date: 12/09/2018 06:59 am
Date: 11/11/2019 03:38 pm
New cam
Date: 01/23/2017 05:11 pm
78 fender and hood
Date: 03/23/2021 01:07 pm
79 Wagon with many extras
Date: 07/08/2020 04:18 pm
Date: 01/23/2017 07:41 am
  • Online today: 1,293
  • Guests: 171
  • Total: 171
Tire (not wheel) sizes?
Started by popbumper, May 25, 2009, 09:48:37 PM
Cheezelinder, Welcome aboard and check the #4 post.
Cheeseliner
yeah, i got 185 70 R 13s on one set of the pinto wheels i have. im lookinf for some 205 or 215 60 R 13s for the back and some "skinnys" up front. I am making a pair of universal traction bars (most are 28 in long and dont fit. it should give it the ole school look! Kenny
75 Pinto Hatchback Runabout. 2.3 EFI Turbo Charged Pinto with C4 and 8 inch 4.11 locker, Front mount IC, NOS, Walbro/T-bars/ Drag Stars
 :welcome:
I love a certain  Big and little look.. but the tire Should have a profile that reflects the BF Goodrich of the late 80's...flat foot print to the ground...and Raised white letters.
Like I said, Chris stick with your vision...
FrankBoss
...and I should have said "THANKS" for the inputs, don't get me wrong, always enjoy hearing from you. The tire size thing has been a bit frustrating!
Quote from: popbumper on June 02, 2009, 04:13:51 PM
I checked - they do not have what I want, their selection sucks as far as 13", and $459 for ONE tire as one of the selections?  :showback:
oh ok
Quote from: Starsky and Hutch on June 01, 2009, 08:37:44 AM
coke tires have what you want,, but they anit cheap by any means
Starliner
Here is a great site for doing tire size calculations and how it will effect your engine RPM's
Link: http://www.differentials.com/calc.html
This site helps you with the rim selection.
Link: https://www.rsracing.com/tech-wheel.html
1973 Pinto 1600 - Sold!
1979 Pinto 2300 - Sold!
I like your thinking, Frank. Smaller tires on front, larger on back, same wheel. Seems like the best solution.
HEY! I owe you some mirrors. I'll get back to you in a day or two once I snag them back.
I bought Cooper, and Pepboy Futura(sp?) tires ...Made by the same Company!!
205 60/13 on the back and 195 70/131 on the front...
I've used these on my Pinto and Falcon for the same Look.
I used to use Kelly Chargers but they stopped making the 13's as well.
Keep with your vision
FrankBoss
Quote from: Carolina Boy on May 26, 2009, 10:47:12 PM
This is the reason I decided to go 5 lug on my car, more selection for both wheel AND tires.
This is so much the "chicken and egg" argument - my problem is, I spent $$ on a set of 13" Rally wheels, so I don't "toss them off" so quickly. I agree with the 5-lug thing, more variety, but then I'd have to mess with redoing my front end (just rebuilt) and changing axles on the rear end. Maybe eventually, but I'll leave it alone right now.
I >wish< I could have the setup I used to back in the early 80's, I had 4-lug 13" wheels on the front, and 4-lug 14" wheels on the back, all with raised white letter tires. It was nice. Things change!
Well, I don't like to go much bigger than P185 on 5.5s. I have 14x6.5s on the car and I use 185s on the front (makes those 215/70s on the back look huge ;D ). My stock thirteens have 165sr13s on them. I looked at the 13's available at coker tire http://store.coker.com/ but there's no 13" raised letter tires there. They have some bias black and white wall and some 13" radials. Might be something there you like, but it's like going to a jewelry store  :hypno:
Chuck  :afro:
I'm curious to see how you decide. I have 225-60-15" on my car now (see small picture next to post).  I like the wheels, but the tires are too tall.  Especially with 3.00 gears!
I got a set of Rally wheels off a Mustang II at Pick A Part for $8.99 each.  No center caps or rings, but they came with acceptable 175-70-13" tires.
Anyway, while funds for tires are not to this economic condition one day I'll be buying some.  It's either going to be (smaller) 205-60-15" or (hopefully if they fit) 205-60-13."  What others post that fit will determine my eventual purchase.  And hey, if the 13" Rally's don't pan out I can always use them on my Sunbeam Tiger.
Tom
Well, I actually went and measured the width of the Rally wheels tonite - turns out they are 6.5", NOT 5.5" as originally thought. SO, a "60" series would fit them fine; that opens up more possibilities for me!
arkyt
Talk about obsolete.  I have TRX wheels on my 77 Cruizer.  The 190/65/HR390 in the front only rub at complete lock in reverse and the 220/55/R390 out back fit great.  New tires? - $300+ for the front and $400+ for the rear.  Time for new rims and tires. Any suggestions on if you can find 14" to fit the rear like I had on my '71?
78 sedan
77 V8 cruizin wagon
73 MGB
09 Challenger RT
I have 185/70/13 on my 80 Pinto and they fit & wear just fine.
Those Summit tires would be great. Not too big, but meaty enough to fill the wheel wells.
Hello all
On 5.5inch wide wheels I would not run much beyond 195 depending on aspect ratio and suspension roll stiffness. On my 72 with 7.5"wide  steelies w/13" diameter, I had Bias ply Kelly Charger B50-13 and they were wider at the tread that the rim bead. Today's radial tires would be tough to get in anything 13" with a serious all season tread . I think Tire Rack has racing type 225/45-13 in multiple brands. Sumitomo has some 13" sizes too.
The Euro car guys can get almost any size in 13" for their killer Escorts.. We Just need to buy more tires from other sources to get the market to come to us :mad:
Sideways under power,
I just did a quick search on Summit and found this.
Cooper Radial white letter, 205/60/13, #39603, $79.95 each
Old school, it was the B-60-13. Summit might have off size tires.
Ack!  >:( Doing some internet searches, I am finding that these 13" sizes are obsolete for the most part.
I have 195's on my 5.5 in Wide rims. They are the 13in Ansen style but the same size wise. 195/70 r13 Discount tire had them, Had to Order from 2 Diff stores tho
Hi all:
 In the process of restoring my Rally wheels. I was curious - what maximum tire size will fit these rims? I know they are 13", and believe the width to be 5.5" (without going and measuring them). When I got them they had 80 series tires on them (yecch), I am hoping they will fit a 70 series, I am probably leaning towards "old school" raised white letters. Any inputs on series and maximum "P" width? Thanks!
