Date: 01/10/2022 03:41 pm
Wanted 71-73 Pinto grill
Date: 03/09/2019 10:45 pm
Date: 12/10/2017 01:14 pm
Date: 08/05/2018 01:58 pm
Date: 01/06/2017 11:42 pm
Date: 07/01/2019 12:23 pm
Offenhauser 6114 dp
Date: 09/12/2017 10:26 pm
Date: 09/20/2018 11:01 pm
1976 Ford Pinto
Date: 07/16/2019 02:51 am
  • Online today: 481
  • Guests: 138
  • Total: 138
351w-->Pinto: Engine plates or motor mounts?
Started by Sherman, October 04, 2004, 10:50:43 AM
Sherman
Excellent. The only real advantage I can see is that plates would leave header room to tuck pipes underneath, with no mounts in the way. But I plan on using that slick "turned around shorty headers" trick, so mounts seem the way to go...
Thanks
Paul
i also used motor mounts for mine, but if you want to use the plate system, do it. There will be more vibration in the chassis from the engine being solidly mounted, so make sure you keep checking on critical nuts and bolts for tightness, as they do seem to work themselves loose!
STALLION76
Hi, I used mustang II  mounts for all,including the trans.I drilled and  put a bolt through them to play it safe . Used 66 mustang cast exhaust manifolds .It fit just right.
Sherman
I've been researching/collecting literature on doing a 351W swap into a Pinto. What I've seen thus far in some of the older manuals is the use of plates bolted to the heads, then to the frame as mounts instead of using proper motor mounts.
Anyone have thoughts on this? Pros, cons? The plates seem easy, and would leave room underneath for headers, oil filter, etc.
Thanks!
Paul
