2.3 carb intake
Date: 07/15/2020 09:25 pm
Date: 09/01/2017 07:52 am
78 pinto wagon
Date: 06/04/2020 12:42 pm
Date: 07/10/2016 10:17 am
Date: 08/02/2019 04:18 pm
72 Pinto Wagon for sale
Date: 12/31/2017 08:40 pm
Date: 08/06/2021 02:23 pm
1971 2 lt Cam
Date: 10/10/2020 06:27 pm
1980 Pinto Wagon
Date: 02/29/2020 07:01 pm
  • Online today: 583
  • Guests: 343
  • Total: 343
Another question from Newbie....
Started by beicholz, May 23, 2009, 08:21:10 PM
I would avoid 71-73 models myself, any 2.0 models and any V6 models. Its just my personal preference but I do have reasons and apparently ford thought the way I did as the 2.3 was the ONLY engine available in 1980. Let me explain my self.
First of. 71-73 cars have a different suspension than the 74-80 pintos. The 74-80 suspensions are common, same as the mustang II and often wanted for street rods and race cars. Parts are not a problem for them. However, this is not the case for 71-73. Some of the suspension parts are available and not hard to get but some of them ARE. I believe it is mainly the lower ball joints that are tough to find, but because of that you can bet if you ever need a suspension part for a 71-73, that will be the one you need and you will have a hard time finding it.
Second. The 2.0 and 2.8 engines are solid lifter engines. While you may get away with rarely, if ever, adjusting the valves, the adjustment is still there and is still considered a maintainence item. The 2.3 has hydraulic lifters and requires no regular adjustments. I would also avoid a 74 2.3 (which basically means no 74, since they had only 2.0 and 2.3 engines). I have a 74 and dont mind working on it but you are worried about maintainence. The 74 2.3s had point type ignition systems and while some argue they are better because they are simpler and easier to fix, they are not high powered systems and they require lots of regular adjustment and replacement. Electronic ignition started it 75. I myself am tired of the points so an MSD ignition is in order for it, or else a fuel injected 2.3. Not sure which.
Anyways, this is my 2 cents. A 75-80 2.3L pinto would be best for you. Dont worry if you find a car with no power steering or no brakes. You don't need them, and it does not at all make it hard to drive. Dont worry about Auto vs 4 speed either. They are both great options. My automatic pinto actually has more power than my two 4 speed pintos, and it is NOT geared lower than the 4 speeds. All of my pintos are 2.3L powered. A/C would be nice to have but its a rare find. You can add aftermarket AC for around $1000.
They corrode, come un-soldered, and otherwise leak.
I know mine had a big hole in it, but now that I replaced mine it doesn't matter... As long as it doesn't go bad again.
Quick question, why dis on brass floats???
That would make sense both my sedan & hatchback had the brass float. Not too sure about a wagon, but it sounds like it used a plastic float. Kinda stupid to use a brass float anyways. If I hadn't already fixed mine I would more than likely use a plastic float if possible.
That's a very good point, someone else with a wagon would have to corroborate (that is, verify) that this is the case!
having read all this about the sending unit   could it be that the wagon one has the plastic and the sedan has the brass. the sedning units hav a different # and supposedly are not interchangeable  as the tank size is different. the wagon  holding more fuel.
That's not rude at all, that's more information! OK, I guess maybe then there were at least two manufacturers that Ford used for these sending units - one with a brass float, one with a rectangular flat "plastic/foam" piece. Mine had the latter. YOur car can be fitted with either one, regardless of year.
The caution however stands - one should not buy a brass float assuming that their sending unit has one; they should pull it FIRST. I realize it's a cheap purchase, but I personally hate buying stuff I can't use - because I have done A LOT of that!
Not to seems rude but I beg to differ, Chris.
My 78 has never had the tank worked on before and it has a round brass float on the sending unit. I know this because it has been in the family since it was new.
I do agree with you on the fact that they did change to plastic, but for which models and what year it was done, I do not know....The 77/78 (77 build) Bobcat wagon I pulled the sending unit from has a thin plastic rectangular float on it. Thin and rectangular due to the tank being slimmer most likely, but plastic, I have no clue.
Also the car will almost definitely need the sending unit float replaced. They were brass and almost always went bad by now, causing the gas gauge not to work.
[/quote]
Little bit of "trivia" to add here. All sending units did >not< have the brass float. The brass float was used on early models but the float was changed to a very light foam/plastic unit later on (not sure when). I know this only because I had to pull me sending unit from my '76 wagon, and it was different.
Not enough evidence? I found a NOS unit - it was exactly the same. Somewhere along the line the brass float was changed, so don't assume that buying one from SSC Enterprises will "fix you up".
Quote from: beegle55 on May 31, 2009, 08:44:54 PM
Very very early Pintos, as in the first run 1971 models, had bugs in the engine such as cam timing and carb issues. But I would say most of those have been serviced in the near 40 years they have had on the roads and that kind of issue would be the least of the problems associated with a car that old. Almost all Pinto's; however, were essentially the same and I don't think there is a bad one in the bunch  :P Just watch for frame rot in the rear and thoroughly inspect a car before buying, but that goes for anything not just a Pinto.  :welcome: and good luck!
i bought my Pinto in late 1970.  i never had any problems with the carb &/or cam issues.  matter of fact, i swapped out the original cam for a hotter Isky very shortly after I bought the car and put on close to 10K miles before going back to the same stock cam (the original cam that came with the car) & carb & a turbo.
On the 74-up years that have the 2.3 if it runs rough it could be a camshaft issue. The 2.3 engine used a slider cam/follower setup and it did create a bad running car when the cam wore out. That's not to say that is something to avoid, as they are easily swapped out with a roller setup out of a newer 2.3l engine. Also the car will almost definitely need the sending unit float replaced. They were brass and almost always went bad by now, causing the gas gauge not to work.
Howdy Beicholz and  :welcome:.
I think every year Pinto had its own unique issues but I can't think of any that had "bugs" (like some Isuzu Troopers with their aluminum heads). Of course the '73 and earlier didn't have the smog stuff and the '71-'76s had the gas tank recall thing. Anyone think of anything?
Of course the older they are, where they're from, very high mileage are areas to check out. If there is a tree growing out of the hood, run away, but take parts. It's all in how much work you are willing to put in it. I myself like '76 and up because of the room in the engine bay for a SBF. But now I will always love the '71 as it was my first.
beicholz
Are there any years / models to be avoided due to maintenance issues?   Other than rust, any problems I should watch out for in setting out to buy a Pinto (hatchback, sedan, or non-hatchback).
1973 Pinto Squire, 59K Miles, 2.0, Auto P/B, A/C
1972 VW Karmann Ghia Convert. (Red/Black), 2K Miles on restoration, One Owner
1972 Chevy Vega (virtual owner - in the junkyard)
2011 Subaru Outback 4WD
1 Yam. Golf Cart: Our "car" on Catalina Island
