door sills
Date: 03/14/2020 03:20 pm
71-73 Hood
Date: 12/07/2018 06:22 pm
Date: 01/24/2017 12:36 pm
Date: 02/28/2024 02:07 pm
1974 Wiring diagram free
Date: 10/27/2019 06:56 pm
Many Parts Listed Below
Date: 04/20/2018 11:15 am
1976 Ford Pinto
Date: 07/16/2019 02:51 am
Racing seats
Date: 10/24/2019 09:41 pm
1971 Pinto 5.0L
Date: 12/02/2017 12:23 am
  • Online today: 531
  • Guests: 476
  • Total: 476
V8 Radiator???????
Started by Twister_Reject, May 17, 2009, 09:46:08 PM
Manuel72, I have the gaskets but next time use the classifieds for parts wanted as this has nothing to do with this post.
manuel72
Anyone know were to get window gaskets for the small windows that sit bay the back seats
 :lol: :lol: :lol: :lol: :drunk:
To each their own.
manuel72
Quote from: Carolina Boy on May 19, 2009, 11:19:55 PM
A cheby in a Pinto, how gosh!
Built ford tough with chevy stuff
manuel72
Quote from: Twister_Reject on May 17, 2009, 09:46:08 PM
I have been working on this car off and on for a year now and I got in a  hurry. I managed to get the v8 and trans in the car without cutting the radiator support. But the radiator I have pretty much makes going any farther with the support intact impossible! So I cut it! Anybody have pics, ideas, or thoughts on fabing a new one around the radiator? Thanks
What i did i put a 350 chevy in mine and moved the motor back 13 inches. the firewall is now at the window and the rad is were its supose to be. the cal is now a bolt on so it can be removed when you need to work on the dist.
entropy
Mine is cut and bolted back in.  The cap is covered by the support, but there's a second one on the upper hose.  I'll try to post photos when I get home and I'm running a big electric fan on a thermostat.
1972 Hoonabout
SBF swap
-308 cid
-CNC ported Brodix heads
8" rear 4.11 posi
G-Force 5 Speed
10 point rollcage
I didnt cut mine either. I followed 71pintoracers advice and cut out for the cap and used a reg fan.
I didn't cut my support, all I needed was a small cut out for the cap. I put the radiator on the other side and I have a regular fan, not electric.
First off is the radiator rated for your V8? What rad are you using? I take, it you removed the hood latching assembly? I ask, because you will have to use a pusher fan on the front of the rad pushing thru, with no fan on the motor. It would be helpful if you showed some pictures of what you've done so far. It is also possible that you will need to mak a "Montcarlo bar"( mounted right behind where the support was weld to each fender) to tie the fenders back in. Without a solid rad support or the bar, your fender will move and shake at highway speeds.
Twister_Reject
