Early Rare Small window hatch
Date: 08/16/2017 08:26 am
Pinto wagon Parts
Date: 06/23/2021 03:25 pm
Date: 04/12/2017 06:57 pm
1971-74 Various Pinto Parts
Date: 01/18/2020 03:44 pm
Dumping '80 yellow Pinto
Date: 06/21/2017 03:45 pm
Date: 05/21/2019 11:50 am
Date: 04/06/2017 12:13 am
1979 Runabout Rear Panel
Date: 01/04/2020 02:03 pm
Date: 10/24/2019 01:43 pm
  • Online today: 295
  • Guests: 194
  • Total: 194
brake lines
Started by woodie, May 17, 2009, 07:49:40 PM
woodie
got the brake line fixed the two flairs I made are holding work and back two days so far
watch this
Quote from: turbowagonman on May 20, 2009, 10:19:31 AM
I've bent my own on two Wagons and it's not that hard. Just pay attention to keep them away from youe exhaust and moving parts. Most parts stores have everything you'll need. My recommendation though is to NOT get a flaring tool from Harbor Freight, they arent that good.
turbowagonman
You are so right. I got one good flare out of the set I got from there. After that I got nothing but bad flares.
To add more info, don't use compression fittings on the brake lines, or atleast the brass ones. Right on the package they state not to use them on brake systems. It's just not a good idea to risk your life on a fitting that may blow out under heavy braking.
turbowagonman
turbowagonman
Woodie what year car you need for.  Fred   :)
Just fyi, if you need the stuff, Summit Racing has a kit with line and tools for less than $100. They also sell just tubing, fittings, tools, by themselves.
Wish I had known that when I junked my truck just becuase it needed brake lines and I thought I couldn't afford it.
Nope, nobody makes any. Gotta bend your own for the car. Had to do mine in 2008 & found that out myself.
woodie
anyone know  if anyone makes preformed brake lines or does any orther car like mustang II come close thanks for any help  Woodie
watch this
