Date: 06/07/2021 08:14 pm
Date: 10/04/2019 08:43 pm
77 pinto cruz. wagon
Date: 06/15/2017 09:18 pm
Date: 08/16/2018 08:54 am
Date: 06/24/2020 06:12 am
Rear brake shoes
Date: 01/23/2017 05:01 pm
Date: 08/09/2018 07:49 am
Date: 03/29/2019 07:20 am
Great Cruise wagon
Date: 12/17/2016 03:39 pm
  • Online today: 1,292
  • Guests: 461
  • Total: 461
The Flying Avocado '73 wagon
Started by blupinto, May 11, 2009, 11:20:55 PM
I went out to see what rear ends I had. Let me tell you, they are heavy! LOL I have 2 (that I can find), and one is an automatic. I actually labeled it 'auto'!! This is when I wised up when tearing cars apart. I found one other one, ( before I started marking them) but I don't know what it is. I do know that hubby just pulled a stick shift rear end out of the grey car. I just don't know if this is is, or if he has it stashed somewhere else!
Here are the numbers. Maybe one of you guy's can tell us what we have here!!
On top of the pumpkin, D12W-4025-A
On the tag, top number = Maybe? and 0 V - T DJD the last letter may be an O though, not sure.
Bottom number = 18 6  7  1212A  I'm not posetive on the 18 either. The tranny was almost upside down and I had to try to wedge it to where I could somewhat read the tag! In fact, I forgot to take the pry bar out! LOL
If this isn't a stick,  I will ask hubby tonight, where he put the stick shift one!
Thank you Kim for the offer. I'll make googoo eyes at Fred to go by Sacramento. Fred... ::) :amazed: :hypno: :o :surprised: It's hard to do googoo eyes with the emoticons at hand.  :lol:
Thank you  71PR. I didn't know that about the tag. I haven't ventured underneath yet because of my dilemma of: I don't have money to get what I need, and if I pull the rear apart that's when the HOA will say I need to get it back on the driveway before I can get what I need. That darn Arnold!  >:(
Kim and Becky, all of the 6.75 rears are the same as far as bolting them in. The only diff is the gear ratio. There should be a metal tag under one of the cover bolts, the ratio is stamped on it. Most were 3:18, 3:40 and 3:55. Becky did you find out where the bolt came from and most importantly, how much damage was done?
I have some rear ends out of 71 and 72 sedans. If we can figure out if one of mine is the same as yours, or if you can just swap the hole rear end (drum to drum) with one of mine. You can have it. Just need to get it to you. Maybe Fred will be able to come through Sacramento on his way home and pick it up and deliver it to you? Fred?  ;D
So when you find out what yours is, let me know and I will will have Bob figure out what we have. Then we will deal with getting it to you!!!!  ;D
If its the same size rear end the gearing might be different but the rest is the same.
It's ok Phil... thank you for the offer anyway... :)
Ok here's a possibly ignorant (or downright dumb question)... If I found a '71 sedan could I possibly use the cover and guts if I had to on the '73 wagon, or are they two different setups based on car length, transmission, etc. ?
i  pulled the cover and tried to clean it  now it looks like swis cheese  i counted 12 pin holes in it  so it is no good  sorry
YIKES!!! I got lucky, huh?
Thank you guys, and thank you Phil for the offer. I am interested, just let me know the cost. I can't get the stuff right away (I'm already overdrawn. Thank you Mr. Governor.) but I'll be swapping eventually. I don't know what the rear end is, all I know is the car's a '73 with 4-speed manual and a 2.0 engine. Judging by the years of grease build-up on the outside I doubt the rear has ever been changed.  :-\
To think I could've had lock-up...with the dogs in the back... (shudder)...
Quote from: srt on August 05, 2009, 07:45:01 PM
ring gear bolt or a differential side bearing cap, bolt.  i had one of those caps break in half once and the result was a locked rear end and a driveshaft through the floor at freeway speed.  it really is easiest to swap in a new/used replacement
Yeah imagine that happening in an AMC Eagle wagon at 75 mph.. lo wasnt a fun night.
Quote from: blupinto on August 05, 2009, 02:53:01 PM
I know I'll have to take the differential cover off (oh what fun.) but that'll be a job for when I'm (finally!) over this dumb cold. I'm still too tired-feeling and muzzy-headed for projects like this. Now riddle me this Batman: is there any way a bolt (!?) from inside the case could've been forced through the dif case? This morning I cleaned off where the dripping was and there's (I swear!) a threaded bolt-looking thing sticking out of the dif cover. There's even a lip of metal that was peeled away when this went through. The car never lost power, had the wheels seize up, nothing- except for that dragging-metal noise I heard coming back from the park. Is this unheard of or is this not so rare for these old road warriors? Thank you for any info, though I'm expecting the worst. As they say, when it rains it pours...
becky it sounds like one of the pinion bolts came out and got Launched into the diff cover. If so youll need to rebuild the rear end. New pinion and possibly new gears inside
if it is a 6 3/4 rear end i have a cover  you can have  just let me know i might even have gears it needed. i think the ratio is 3:18   the rear end is still on the car   and i dont need it  the drums froze up on it from sitting so long.
Quote from: blupinto on August 05, 2009, 03:28:41 PM
:lol: :lol: Lookk fast Kimmy before the s word you put in turns to zoop... :lol: :lol:
LOL I didn't even think about it when I wrote it! LOL I just don't consider that a bad word. Maybe it was taken off the "zoop" list! LOL
On a sadder note no, it's not the filler hole. The filler hole is on the side, not rear-facing. Anyway, the business end of a bolt (?!) shouldn't be protruding and that incriminating lip of metal tells me something stinks... and it's not the gear oil (well, that smell makes me want to gag.  :P) I wish it were a filler hole. Those can be easily replaced. The plug, that is.
Well that sucks Becky!  :'(  I can't tell that well by the pics, but it looks like it is leaking out of the filler hole. Also looks like it has been leaking for a while!! I sure hope it is an easy fix!!
Get well soon, so you can update us on this!!  ;D
Time to remove the cover and see whats underneath hun. No idea if you ruined it but it looks like its got a leak somewhere. Perhaps at the filler. not sure but that looks to be an 8in rear end but i could also be wrong, it looks taht way cause of the grease. it could still be the 6.75 rear but the bolts are covered in grease and not visible. anyways id remove the cover if its the 6.75 and check for loose bolts on the Pinion, Shavings anything that would Indicate that you might have ruined it. but rear-ends can be rebuilt.
Possible bad news.
Now don't beat me up too much. Ive been doing enough of that already.  :(  I took my Green Girl to the dog park (naturally with dogs in tow) like usual, but on the way back (in the dark, also naturally) I heard noises like something underneath FA was either hitting the asphalt or the inner wheel/tire (we were traveling at speed) and at one point I pulled over on the highway and looked at the exhaust pipe and muffler (it's been a lil' loose lately) but nothing dragging or appeared to be missing. She accelerated and shifted like normal but that horrible noise would come again- then go. After I got home I got my flashlight and found a) a grease smell, and b) a grease puddle and drips- coming from the differential housing. Because it was dark I didn't try to clean it off or anything, but I hope someone can see the pic and tell me if I ruined my green baby.  :'(
Practice makes perfect, Becky  :). Glad to hear you are making progress!
Chuck :afro:
Well, for some good news: I'm a lot better at driving FA. I barely stall her at intersections anymore. I'm getting the friction piont down. YAY!  :happy_bday: Bless her, when I follow the starting procedure (when starting her from being parked) she fires right up. Sometimes I have to lightly tap the accelerator to keep her going, but still...
      She does bog sometimes and I know nothing about when her fuel filter was last replaced so tomorrow I'll be doing that. Sometime in the (hopefully near) future I'll be also re-securing her exhaust pipe. And replacing her steering wheel. And finishing the sewing of her headliner. And ... ::)
My best friend suggested a couple pink flamingos in the trunk area.  ??? ::) :lol:
Quote from: discolives78 on May 14, 2009, 10:16:40 PM
Guacamole on the hoof.
My suggestion for the roof is Astro turf. cover the entire roof in carpet glue and cover the whole roof in green astroturf. Then use a hole saw to cut a 3 inch hole in the center of the roof near the back and secure a piece of PVC with a cap on one end to the inside of the roof with a flange like a toilet uses (available at home depot) Then place a golf flag next to the hole. Next get a golf putter and a few golf balls. When you get stranded, you can practice putting on the roof while you wait for help. ;)
Just kidding! ;D
I'm from the desert, I don't see much rust!
Chuck :afro:
LOL That was too funny!!! LOL But, you know that would go with the shaggy green carpet on the inside!!!!!!!! LOL  Sorry Becky, had to say it!! LOL
By the way, Welcome back Chuck!!!!! Nice to see you posting again!!!
Just kidding! ;D
Chuck :afro:
HAH! lol.  :lol: :lol: :lol:
You mean The Pinto That Tried To Be A Maverick Cow?! Poor thing... My heart bleeds for that wagon... :'( :laugh: :lol:
Yo Blu, At least it would look better than that wagon with the Pinto spots!!! :lol:
Yeah... looks like I need to break out a can of...
Quote from: blupinto on May 13, 2009, 10:31:17 PM
Yes I have... briefly. I'm funny about this. I would rather mave mismatched (color) parts than get the parts repainted to match. Because she's not the "show" car I'm not that concerned about her odds n ends. Plus, the paint would have to match the sun-faded color or it'll have the same effect as the blue parts.  :look: :-\
       Yes, CB you are a tease extraordinaire. Here's your crown.  :angel: :P :laugh: lol. Can you imagine- saddle naugahyde vinyltop on a forest green wagon...that won't elicit strange looks... ::) :rolleye: ;)
      more on why my driving her needs its own project thread later... :embarrassed: ??? :read: :reek: :showback: :nocool:
71HANTO SAYS....YOU...
Sounds like you got yourself a plan Becky.... I like the "beckyspeak" :D . Have you thought of using vinyl paint/dye for the mismatched parts?
Ya know I was just a pickin' at ya? :evil:
