NOS Sedan decklid
Date: 10/23/2019 11:51 am
73 rear hatchback glass
Date: 07/06/2017 11:33 am
Date: 05/03/2024 05:37 am
79 Wagon with many extras
Date: 07/08/2020 04:18 pm
Hood Hinge rubber boots
Date: 09/28/2018 05:49 pm
Date: 02/22/2017 01:58 pm
1977 Pinto Hatchback Parts
Date: 08/29/2020 05:31 pm
ford pinto door panels
Date: 03/20/2022 07:51 pm
Rear Bumper
Date: 07/26/2021 01:08 pm
  • Online today: 489
  • Guests: 232
  • Total: 232
350 Holley on an '80 - what's required?
Started by dba900, May 11, 2009, 09:26:52 AM
dcorry
my stock carburator crapped out on my 79' wagon. The local auto parts store wanted a arm and a leg for a new one plus I would have had to wait 3-4 days. Had a 4412 Holley left over from my racing days on the shelf.Modified the throttle bracket a little and added a thick gasket and away I went.Had to change the jets from #78 to #72 ...WOW that Holley looks cool under that hood.My next project will be to lower the drivers side floor board down about 2" so the gas pedal will go down farther.The farther down the gas pedal goes the faster you can go right? Isn't that how it works?       :fastcar:
Hurricane Katrina victim saved from the scrapyard  --79Pinto--
dba900
dba900
Quote from: 71pintoracer on May 11, 2009, 05:10:57 PM
Remove the EGR plate, bolt on the 350 and enjoy!  ;D You may or may not have to do some minor fab work for the throttle linkage. You can get the carb with an electric or manual choke.
Sounds pretty straightforward. Did the '80s have an electronic choke? You actuate it by pushing the pedal to the floor; it comes off by itself.
Thanks,
David
Lost Coz
I put a Holley on my 73 wagon. It was not a real problem. I bought a Spearco manifold for the 4 barrel, which was an easy bolt on. I had to fabricate a bracket for the stock cable to adapt to the carb, but that was the only minor thing besides getting the jetting right after install. It shouldn't really be a big problem for you. It really made a difference with the cam, electronic ignition, and headers that I put on it. Lots more power....
"Pinto's are cool"!
"Pintos are cool!"
1973 Pinto Wagon
1974 Pinto Wagon
1975 Pinto Wagon
74 Pinto Wagon for parts
dba900
I'm thinking of swapping a 350 Holley on my otherwise stock '80. What parts do I need to complete this swap? Is it pretty much a bolt-on, or do you need to adapt the choke, etc.? Is it worth doing?
Thanks!
David
